Self-Powered MIDI Splitter?
Re: Self-Powered MIDI Splitter?
Postby zenguitar » Sun Jan 14, 2018 1:47 am
Might this come close Martin?
https://amptonelab.com/products/midi-strip/
Yogi Berra
Postby Tuseth » Sun Jan 14, 2018 2:03 am
If ur dawless ur going to have to have a midi thru and they all need some sort of power source if not just use your computer to do all the midi ins and thru's with your daw you could send your arturia beastep to all the channels you want... ;)
Tuseth
Tuseth
Postby Tuseth » Sun Jan 14, 2018 2:04 am
Tuseth
Tuseth
Postby Martin Walker » Sun Jan 14, 2018 3:39 pm
zenguitar wrote:Might this come close Martin?
Actually, that's pretty close Andy - thanks! :thumbup:
I assumed all of this range of products would require a deep cavity, but as you can see from this photo of all its parts, the control unit is entirely separate from the resistive strip, which is in turn only a couple of mm thick.
Hmmm... this might work!!
Whoops - sorry for the hijack Bob ;)
Postby BillB » Tue Jan 16, 2018 7:07 pm
Also sorry for the hijack, but to continue....
How are you going to programme pitch bend or vibrato, Martin? It seems to have 4 modes, each with specific CCs and channels (targetting Kaoss Pad etc), and no obvious way to program it. Interested to know what you have in mind...
:geek:
BillB
Postby Martin Walker » Wed Jan 17, 2018 1:50 am
BillB wrote:How are you going to programme pitch bend or vibrato, Martin?
Ah, I haven't looked into that closely yet Bill :beamup:
However, most DAWs allow you to convert one MIDI message into another, so I would hope that these specific CCs can be convinced to generate pitchbend information :headbang:
Postby BillB » Sat Jan 20, 2018 8:42 pm
OK, I see - if you are going through a DAW or Bome’s MIDI translator etc, it would be fairly straightforward. I was assuming you wanted a hardware solution.
BillB
