KORG VOLCA's Buttons MOD !
Postby eduraf » Wed May 09, 2018 10:40 pm
Let me share with you all the Mod I have made on my Volca Sample. These small coloured knob caps fit almost perfectly with (any) Volca's knobs and give a much greater feedback / grip / view of the knob position.
I bought them from Thonk UK: https://www.thonk.co.uk/shop/micro-knobs/
Here is the procedure for mounting the knobs using only standard little pieces of foiled paper to make the caps fit nicely without "sliding" of position:
Have fun !
eduraf
Re: KORG VOLCA's Buttons MOD !
Postby craigtumps » Thu May 17, 2018 3:53 pm
Nice idea :thumbup:
Im ok with the standard knobs but I have a Volca Kick so much less knobs than the Sample.
craigtumps
Postby Martin Walker » Thu May 17, 2018 8:11 pm
Hi eduraf, and welcome to the SOS Forums! 8-)
Even better, you've provided a good-looking and very functional DIY tip on your very first post, so bravo for that :clap:
I'll shift this into our dedicated Keyboards and Synthesis section so all the synthheads spot it, but will leave a link here so everyone can follow the thread.
Postby Richie Royale » Thu May 17, 2018 9:30 pm
Welcome to the forum. I second Martin's comment, great first post. Have you experienced any slipping with the knobs at all?
I've only got the Bass and that has only a few of the smaller knobs, so not really a mod I need to apply.
Richie Royale
Postby Ben Asaro » Sun May 20, 2018 1:52 pm
This looks like a must have for my SQ-1!
Ben Asaro
Postby Martin Walker » Sun May 20, 2018 7:43 pm
Richie Royale wrote:Have you experienced any slipping with the knobs at all?
I'm reasonably certain you can avoid this, since the original pots already have a toothed finish, while the Thonk knobs are specifically designed to mate with such a surface.
If you're worried about using a shim of shiny-surfaced paper, just use a matte finish instead so it gets more easily 'mashed' when you push on the outer knob - that should hopefully make things more permanent. Fine corrugated paper might be an even better choice!
Users browsing this forum: Dan LB
