Behringer Neutron - couple of oddities...
Postby The Elf » Wed Aug 15, 2018 9:19 pm
Just started fooling around with one of these Neutrons and I've hit a couple of snags.
Portamento only works when USB/MIDI notes are played legato. I can't find any way of latching it. I tried using slew, but any signal from the slew jack *adds* to the internal pitch CV generated from incoming MIDI, so the pitch tracking goes wonky. I guess slew would work via CV, rather than MIDI, but that's not the way I want to connect it. Any ideas?
I wanted to use a MIDI mod wheel to add vibrato.
I connected LFO output to ATT1 input and ATT1 output to the OSC1+2 CV input.
I assigned mod wheel to the ASSIGN assignable CV output and connected this to ATT1 CV input. Job done, I would have thought...
As soon as I plug the jack from ASSIGN to the ATT1 CV input it generates vibrato all the time, even with the ATT1 control all the way down - moving it sends the vibrato crazy. It's as if there's a Voltage coming through the Assignable output, even without moving the MIDI mod wheel. Again, any ideas?
It's a great-sounding synth, and I can forgive it a lot, but these things seem pretty fundamental to me. If anyone else has one I'd love to know if your's is the same, or if mine is faulty! :headbang:
Re: Behringer Neutron - couple of oddities...
Postby Nic-MusicTribe » Mon Aug 20, 2018 3:53 pm
Hi ...,
Please allow me to introduce myself; my name is Nic and I am a Technical Support Specialist at MUSIC Tribe Brands in Kidderminster, UK where we support products and provide servicing for all MUSIC brands.
In regards to your Neutron, we would love to help you resolve your issue. Would you be able to contact our technical support team to discuss the problem in more detail?
You can reach us at carecrea@music-group.com or by telephone on:
+1-702-800-8290 (US)
+44 1562 732299 (UK)
Nic
Specialist, CARE
MUSIC Tribe | Home
BEHRINGER
Nic-MusicTribe
Postby Dave B » Mon Aug 20, 2018 6:59 pm
Ooh look - this one's identified themselves as an employee. Wonder if his written English will be up to the high standard set by the Russian troll?
:bouncy:
Dave B
Postby James Perrett » Mon Aug 20, 2018 7:33 pm
Funny how the Behringer representatives always post once with the same standard reply and then disappear - never to be seen again. Nic could just as easily have explained whether the behaviour that Elf was seeing was correct or not - which would probably have saved them support effort as anyone else with the same problem could see the reply here rather than having to contact them.
Postby topaz » Sun Oct 28, 2018 5:40 pm
10. Patch ASSIGN to ATT1 CV, set ASSIGN to MOD WHEEL, patch ATT1 OUT into OSC 1&2 pitch CV, this way the mod wheel sets the depth of vibrato, with LFO rate/ shape setting the characteristics and ATT2 setting the maximum depth.
ATT2 only needs the slightest nudge up for this to work.
The Elf wrote:Just started fooling around with one of these Neutrons and I've hit a couple of snags.
topaz
Postby The Elf » Sun Oct 28, 2018 7:47 pm
That sounds like what I did, but it wouldn't work properly, as I noted above. My Neutron isn't with me for a while, so I'll be sure to try again when I get the chance.
