Any Korg Z1 users out there? Value/program buttons not working.
Postby tek_ukLondon » Tue Sep 18, 2018 8:55 pm
Hi all,
I recently picked up a damaged Z1 for cheap.
It had a few broken keys and missing encoder knobs but was working otherwise.
I replaced the broken keys so all good.
However, I'm pretty sure that when I picked it up, the Program/value buttons worked (albeit a bit sticky). I then did a factory reset and they no longer work, however the Page/User group buttons now perform the same function, i.e if if press them they increment/decrease programs by one! (whereas according to manual it should move to programs in same category). I re-did the factory reset a few times... same behaviour.
Any idea what could be wrong? Can't find any global settings that could affect that.
I should point out that that behaviour changed before I opened it to change the broken keys so unlikely to be the result of plugin/unpluging cables inside.
Any ideas welcome.
Lars
tek_ukLondon
