Hi Folks,
I have both a Mother 32 (M32) and a Subsequent 37 (S37)
Having determined in another thread that I can connect my two synthesisers together, I have come up against a problem that is probably of my own making but here goes!
If I connect the VC Mix (output) of the M32 to the Pitch CV (input) on my S37 and press a key on the Sub keyboard, I can control the pitch using the VC Mix so I know that the cable and Pitch CV are working fine.
However, if I patch the KB Out on the M32 to the Pitch CV on the S37, there is no change in pitch. I have checked that there is a voltage change on the KB Out using an oscilloscope both on and off 'load' and am getting a clear voltage change amounting to 1 volt per octave.
Am I missing something?
Any help would be gratefully received.
Thanks
Steve
Connecting Mother 32 KB Out to Sub 37 Pitch CV
• Page 1 of 1
Durr GaGa - Poster
Regards,
Steve
www.nightskyimages.co.uk
Re: Connecting Mother 32 KB Out to Sub 37 Pitch CV
Do you need to send a gate signal as well as the pitch CV to open the amp/filter?
Also, check the CV mapping (Global menu 2.1) to make sure the control voltage is going where you think it is!
Hugh Robjohns - Moderator
Hi Hugh,
Thank you for responding.
As the VC Mix works fine if I hold a key down on the Sub 37, this would seem to be opening the amp/filter and is in line with the manual but I will research this aspect further.
Thank you for this, I have now checked the CV mapping in Global menu 2.1 and the Pitch CV is set to 'default' so I believe it is working correctly.
I have also tried running a sequence on the Sub 37 and then pressing a key on the Mother 32 but this has no effect although, yet again, an output from the Mix CV changes the sequence's pitch.
All a bit perplexing at the moment as I know the voltage from the Mother 32 is changing in sensible steps and I know that the Pitch CV connection on the Sub 37 is working!
This will teach me to run before I can walk!
Thanks again for your input.
Steve
Steve
Durr GaGa - Poster
Regards,
Steve
I have now solved the mystery!!
Like so many issues, the solution is so obvious when you know the answer! This is all to do with the Mother 32 having a pitch CV running from -5v to +5v whereas the CV input to the Sub 37 and Subsequent 37 works from 0v to +5v.
Using octaves above 4 on the Mother 32 supplies positive voltages which correctly adjust the pitch of the Sub 37.
I now need to find a voltage converter to give me a little more flexibility and believe that the Erica Synths MScale module may do what is required but I am going to try and find a DIY solution first as I am several steps away from going down the Eurorack path!
Durr GaGa - Poster
Regards,
Steve
Doh!
Yes, of course -- I should have thought of that. Sorry. Glad you sussed it though.
Thanks, Hugh, I can't take the credit for discovering the reason for the problem as I found the missing piece of information on line but thank you all for your input.
Regards,
Steve
Regards,
Steve
Durr GaGa - Poster
Regards,
Steve
A Precision Adder will do the trick as well, but you should just spring for a Disting; it's the best friend your modular, or semi-modular could have!
- Ben Asaro
- Regular
Thank you Ben, what an amazing device - I don't think I've ever seen so much functionality in one small module!
Regards,
Steve
Regards,
Steve
Durr GaGa - Poster
Regards,
Steve
Yes, it’s an incredible piece of kit that seems to have new functionality added all the time. What I love about it, besides the versatility, is that you can try just about every type of module available and then purchase a dedicated module if needed. The Disting has ended up costing me thousands lol!Durr GaGa wrote:Thank you Ben, what an amazing device - I don't think I've ever seen so much functionality in one small module!
Regards,
Steve
- Ben Asaro
- Regular
Ben, you're selling me on this .............
Before I get onto that carousel though, I really must work harder on getting up to speed with what I already have as I am still a newbie nearly a year after buying my first bit of kit ...
Durr GaGa - Poster
Regards,
Steve
That is absolutely the best way to do it! Take you time and get to know each piece before you move on. My modular has been a very slow moving process. I started with a Mother-32, then added a second oscillator, then made that second oscillator into a complete voice, etc etc.
- Ben Asaro
- Regular
