Just out of curiosity, what is an S2v file?
Postby Stickman0_3 » Tue Apr 02, 2019 9:07 am
Is it similar to a Midi File?
Stickman0_3
Re: Just out of curiosity, what is an S2v file?
Postby Dave B » Tue Apr 02, 2019 11:32 am
A quick google says that this is the file format used for the Yamaha S80 and S30. Apparently. Do you own a Yamaha S-Series?
Dave B
Postby Eddy Deegan » Tue Apr 02, 2019 12:28 pm
Stickman0_3 wrote:Is it similar to a Midi File?
As Dave said, it looks to be a Yamaha S80/S30 Voice Editor File. If this is the case then the software that can open it can be found here: https://europe.yamaha.com/en/support/up ... 59_en.html
I doubt it contains any note information, more likely it's a voice data dump.
Some of my musical works.
Postby Stickman0_3 » Tue Apr 02, 2019 1:29 pm
I own a Yamaha CS6x and had programmed 128 sounds for it. I had trouble saving a Midi File, so I saved the sounds to a Smart Media card. I found a USB card reader, connected it to my computer, inserted the card and copied the file onto the desktop. I now need to see if it will load back into the CS6x.
Stickman0_3
