Good USB sound module?
Page 1 of 3
PostPosted: Sun Apr 07, 2019 8:05 pm
by ConcertinaChap
Hi all,
We have a Yamaha P115 which the pianist in my wife's band uses. She (the pianist) has a hankering after playing more sounds than the small set that comes with the piano. The piano's MIDI connection is USB. Is there such a thing as a sound module or expander that can connect to the piano? The module would have to have a type A port because the piano's USB port is type B. Ideally it should be jolly easy to use (I'm not always going to be around), have some good sounds and be battery powered (sound will be provided by a Bose S1 Pro).
Is there such a beast?
TIA,
Re: Good USB sound module?
PostPosted: Sun Apr 07, 2019 8:18 pm
by Dan LB
I don't know of any off the top of my head, but you can get USB to MIDI converters (aka USB MIDI hosts) from the likes of Kenton and Hobbytronics and there was also one reviewed in last months SOS from Retrokits:
https://www.soundonsound.com/reviews/retrokits-rk-005
If you had one of these it would allow you to use any MIDI sound module with a DIN input.
Kenton USB MIDI host review in SOS:
https://www.soundonsound.com/reviews/ke ... i-usb-host
Hobbytronics MIDI USB to DIN converter:
http://www.hobbytronics.co.uk/audio-mid ... -converter
PostPosted: Sun Apr 07, 2019 8:19 pm
by The Elf
I'm not aware of any synth module with a USB host port, though that doesn't mean one doesn't exist somewhere.
One option would be to attach to something like a Kenton USB host/MIDI converter. Once you have that you can attach to any MIDI module that takes your fancy. That avoids a computer at least. But...
...what's the budget?
Dan beat to me to it!
PostPosted: Sun Apr 07, 2019 9:29 pm
by Jumpeyspyder
PostPosted: Sun Apr 07, 2019 10:02 pm
by Sam Spoons
So you buy a USB-Bluetooth adapter which needs plugging into both the instrument and a wall wart? You might as well use a wire :headbang:
PostPosted: Sun Apr 07, 2019 10:14 pm
by ConcertinaChap
Unfortunately you're confirming what I thought the score might be. I'm already using a Hobbytronics USB-MIDI converter to connect the piano to my Philip Rees 5x5 MIDI switch (yes, there's people still using them) in my studio setup but I was hoping for something simpler for non-techies to set up and without requiring lots of power bricks. Never mind ...
Cheers all.
PS budget not a significant issue. Ease of use is.
PostPosted: Sun Apr 07, 2019 10:32 pm
by The Elf
ConcertinaChap wrote:PS budget not a significant issue. Ease of use is.
Then I'd go for a Roland Integra 7 module. If you can't get a decent sound from that it probably doesn't exist!
(Please buy two and send one to me too!)
PostPosted: Sun Apr 07, 2019 10:36 pm
by Folderol
Good Lord!
I just looked that up.
Not exactly a cheapy is it?
PostPosted: Sun Apr 07, 2019 10:39 pm
by ConcertinaChap
"That's got me theer", he said, wit' poozled look in th'eye.
I could see me justifying it (after a lot of shekel counting) for my own use but not for the band - easy to use or no it looks scary.
PostPosted: Mon Apr 08, 2019 12:23 am
by rurs
There's this jobbie:
https://www.dv247.com/en_GB/GBP/Miditec ... 004675-000
I can't imagine the sounds are amazing, but at least there's a selection. 3.5mm output is never ideal either, is it?
At the other end of the spectrum, how about a granular synth...
https://www.schneidersladen.de/en/tasty-chips-gr-1.html
I'd love to try this one myself.
I'm sure I've come across other "boutique" modules with USB host ports, but I can't place them off the top of my head.
PostPosted: Mon Apr 08, 2019 12:50 am
by James Perrett
Embedded PC with a touch screen that automatically boots up into your favourite virtual synth?
PostPosted: Mon Apr 08, 2019 7:33 am
by ConcertinaChap
Rurs, you're spot on what I'm looking for in terms of facilities. I have to say as you do the Miditech Pianobox Mini doesn't look too promising on the quality front but hey! at just 75 squids I might just give it a whirl anyway!
Cheers,
PostPosted: Mon Apr 08, 2019 7:58 am
by Wonks
They missed a trick by not having a hardware MIDI out. As most non-analogue synths and keyboards already have a GM sound set somewhere inside them, it seems rather a strange product.
PostPosted: Mon Apr 08, 2019 8:22 am
by Logarhythm
CC, I've got a Yamaha MU128 sat doing pretty much nothing, that you're welcome to try if useful?
Not of the same calibre as the Integra but suspect it'll outperform the Miditech unit.
You'd still need to use a Kenton unit or similar to deal with the USB B to DIN conversion for MIDI.
PM me if potentially useful :thumbup:
PostPosted: Mon Apr 08, 2019 8:33 am
by The Elf
ConcertinaChap wrote:"That's got me theer", he said, wit' poozled look in th'eye.
It's actually trivially simple. If that doesn't suit then I'd still suggest an older JV (JV-1080 etc) or XV module, which are cut-down versions of the same idea. You'd just leave it in single sound and choose a sound with the wheel. It really is that simple - I know, because that's how I use 'em! Essentially they're just a huge bucket of good sounds.
Then there are the old Emu Proteus modules - again, just leave them set to single sound and turn the wheel to go up/down the patch list.
I know they look a bit scary, but they really aren't.
