‘True Stereo’ hardware FX used with hardware synths
Re: ‘True Stereo’ hardware FX used with hardware synths
Postby Hugh Robjohns » Sat Jun 01, 2019 11:46 am
Ben Asaro wrote:Now, I know people were poo-poo'ing the idea of mid-side processing being an effect; and I agree, it's a process, not really an effect -- but I'll be damned if you can't hear it on these examples; it definitely creates a really interesting sound: it has stereo width but also a really strong center image with lots of low frequency girth. Adding the reverb makes it suuuuuper wide, however.
Sorry... I'm still at a loss as to exactly what your processing chain is and what's feeding the inputs of the MS decoder...
But MS isn't an 'effect' or a 'process', it's a format conversion, plain and simple. The more you put into the Sides channel, the wider the image gets.
Postby BillB » Sat Jun 01, 2019 3:28 pm
Ben, just to say thanks, I’ll give the demo a good listen.
BillB
Postby Ben Asaro » Sat Jun 01, 2019 4:49 pm
Hugh Robjohns wrote:Sorry... I'm still at a loss as to exactly what your processing chain is and what's feeding the inputs of the MS decoder...
Sorry, Hugh -- see a more granular breakdown below:
TX7 MONO OUT > LRMSMSLR LEFT IN
LRMSMSLR SIDE OUT > Lexicon Alex [chorus effect] MONO IN
Lexicon Alex [chorus effect] MONO OUT > LRMSMSLR SIDE IN
LRMSMSLR LEFT OUT > 18i20 INPUT #1
LRMSMSLR RIGHT OUT > 18i20 INPUT #2
^ That's the penultimate round in the loop. On the final loop, it's the same but with a second effects processor added with reverb:
LRMSMSLR SIDE OUT > Lexicon Alex MONO IN
Lexicon Alex #1 [chorus effect] MONO OUT > Lexicon Alex #2 [reverb effect] MONO IN
Lexicon Alex #2 [reverb effect] MONO OUT > LRMSMSLR SIDE IN
Ben Asaro
Postby BillB » Sat Jun 01, 2019 5:06 pm
And the Mimiq?
BillB
Postby Ben Asaro » Sat Jun 01, 2019 5:37 pm
BillB wrote:And the Mimiq?
When I used the Mimiq:
TX7 MONO OUT > MULT
MULT Out #1 > Mimiq MONO IN
MULT Out #2 > Mimiq STEREO IN
Mimiq MONO OUT > Lexicon Alex #1 [chorus effect] MONO IN
Mimiq STEREO OUT > Lexicon Alex #2 [chorus effect] MONO IN
Lexicon Alex #1 [chorus effect] MONO OUT > 18i20 INPUT #1
Lexicon Alex #2 [chorus effect] MONO OUT > 18i20 INPUT #2
Ben Asaro
Postby Hugh Robjohns » Sat Jun 01, 2019 6:02 pm
Ben Asaro wrote:Sorry, Hugh -- see a more granular breakdown below:
Thanks Ben.
LRMSMSLR SIDE OUT
Erm... Wih nothing going into the right side of the MS encoder, the Side out signal will be the same as the left in, but possible with a small level change.
The encoder matrix equations are Mid=Left+Right (which you aren't using), and Side= Left-Right... But, as there is no Right input signal involved here, you just have Side=Left... So no change at all (other than level, possibly -- some MS coders introduce a -3dB level shift downwards to maintain unity gain through a complete LR-MS-LR chain).
...Lexicon Alex [chorus effect] MONO OUT > LRMSMSLR SIDE IN
LRMSMSLR LEFT OUT ...
Again, with no Mid input to the decoder nothing much happens here. The relevant matrix equation is: Left = Mid+Side (and Right=Mid-Side), but as there's no Mid signal you just have Left = Side... So no change once again.
So I'm still quite confused... But maybe this bit is doing something more useful:
> 18i20 INPUT #1
Where do input 1 and input 2 figure in the grand scheme of the MS matrix chain?
Postby Ben Asaro » Sat Jun 01, 2019 7:02 pm
Sorry if this is baffling, I admit I don't know why it works, either! But it definitely does something to the stereo image, as you can hear.
I double-checked my notes to make sure I wasn't running the mult into the mid-side encoder; but, nope, it was going mono into the left input and stereo out to the 18i20, inputs 1 and 2 (as a stereo pair).
So, yeah, it's just as I wrote it -- mono in, side out to chorus, side back into the encoder, stereo out. The actual stereo field is quite narrow if you listen to it, so maybe it's just processing the phase differences caused by the chorus itself; whereas, when I added the reverb, you can clearly hear the wet signal panning from hard left to had right...
*shrug* Dunno!
Ben Asaro
Postby Ben Asaro » Sat Jun 01, 2019 7:04 pm
Edit: Though it's entirely possible that I sent the MID out and SIDE back in after the chorus; I didn't take any photos as I didn't anticipate doing such a detailed post mortem. :)
However, based on what I am seeing here, if I am interpreting this correctly, using mid or side out makes no real difference.
Ben Asaro
Postby Hugh Robjohns » Sat Jun 01, 2019 7:35 pm
Ben Asaro wrote:So, yeah, it's just as I wrote it -- mono in, side out to chorus, side back into the encoder, stereo out.
Okay. I was being dim, but realise now what you meant about input 1/2...
So while all the previous MS messing about was doing nothing at all, as I explained, here you have a mono chorus effect feeding only the side input of an MS decoder, so the left and right decoded outs will be identical, but in opposite polarities, and hence sound ultra wide when auditioned in stereo.
Left = Mid+Side, Right = Mid-Side, so in your case Left = chorus and right = polarity-inverted chorus.
But I do wonder if there's any normalling of the sockets on the MSLR chain, as that would make things more interesting...
Postby Ben Asaro » Sat Jun 01, 2019 7:44 pm
Aha! Mystery solved! :D
Hugh Robjohns wrote:But I do wonder if there's any normalling of the sockets on the MSLR chain, as that would make things more interesting...
That could very well be the case; WORNG is not very forthcoming about the actual circuit and most people using it are probably just interested in creating whooshing pads in their modular setup. I've been using it as more of a spacial "de-centraliser". However, with just the chorus, there is still a strong central image (with quite a bit of bass, too), which definitely lends credence to this theory!
But WORNG is making some of the most interesting processors out there right now (in my opinion); when you combine their Vector Space module with the LRMSMSLR, things get very interesting, indeed! (Though the price of entry is a bit high)
Ben Asaro
