Roland MC-500 incoming!
Re: Roland MC-500 incoming!
Postby Adam Inglis » Tue Jun 25, 2019 11:26 am
Still using my MC-50. The great thing about these sequencers is you can lock their timing to your DAW via FSK when you need to get some audio happening alongside your midi - way better than midi clock!
http://mezzoauto.blogspot.com/2014/08/r ... encer.html
Very fast way of writing phrases and rhythms, once your cerebellum gets the hang of the key combos - no mouse!
Adam Inglis
Adam Inglis
http://www.adambaby.com
Semi-Automatic
Funboys
Postby Ben Asaro » Tue Jun 25, 2019 12:08 pm
That idea intrigues me. I am using Logic Pro X and after a quick search couldn’t find anything under FSK/FSK sync. Going to have to take a closer look.
Ben Asaro
Postby Adam Inglis » Tue Jun 25, 2019 12:31 pm
Some of the info here may help...
http://www.adambaby.com/studiotech_sync.html#smartFSK
HTH
Adam Inglis
Adam Inglis
Semi-Automatic
Funboys
Postby Ben Asaro » Tue Jun 25, 2019 12:37 pm
Groovy, thanks!!
Edit: that blog is @ treasure trove!
Ben Asaro
Postby nathanscribe » Wed Jun 26, 2019 9:02 pm
I still record a clock from the LinnDrum as audio into the DAW, then run that back out and send analogue triggers to step sequencers and whatnot. I've had way too much trouble with MIDI working differently on different devices with how they respond to start/stop/continue etc. Can't be bothered. Give me the simplicity of having to do everything the long way round!
nathanscribe
Postby BillB » Wed Jun 26, 2019 9:52 pm
This is really interesting. It sent me scurrying off through my manuals, to see which of my old gear might play the game. Answer: TR-626 and SQ80, but both seem to require tape synced from start of song, no ‘smart FSK’ to MIDI SPP here. But am I missing something? Why not set a piece of hardware (drum machine, sequencer) as the master MIDI clock, and have the DAW slave to that? Or is the problem still that the sync signal is transmitted by MIDI? And perhaps that DAWs don’t slave well to Sync signals? Not explored this issue either way around, but I’m curious.
BillB
Postby Adam Inglis » Thu Jun 27, 2019 3:18 pm
BillB wrote:Or is the problem still that the sync signal is transmitted by MIDI? And perhaps that DAWs don’t slave well to Sync signals? Not explored this issue either way around, but I’m curious.
Yes, both.
Midi being a serial protocol doesn't do timing clock accurately. Even if you can guarantee there will be no other messages on the bus i.e. you have a dedicated midi clock cable, there can still be significant jitter. Using audio sync signals minimises jitter enormously, and keeps your midi busses free for notes and CCs etc. My standard DAW template has a sync track that drives two Innerclock Sync locks, an FSK track that drives a Roland MC-50, and an audio clock for the little Korg SQ-1. Once the latencies were adjusted for, it's set and forget.
And yes DAWs are generally pretty terrible at smoothly following a tempo clock that might be running at 24 pulses per quarter note.
Adam Inglis
Adam Inglis
Semi-Automatic
Funboys
Postby BillB » Thu Jun 27, 2019 4:26 pm
Thanks Adam, good to know.
BillB
Postby Ben Asaro » Fri Jun 28, 2019 1:50 am
Had my first check using the MC-500 last night. It ran out of memory! Fortunately, I was able to get the finishing touches done. So, lesson learned: check Available Memory often and plan bounces out carefully!
Fortunately the MRP-500 let's me stack songs. :)
FYI, I was able to fit about 80 measures with 7-8 MIDI channels of continuous data before it ran out of memory.
Ben Asaro
Postby Ben Asaro » Thu Jul 11, 2019 5:31 pm
Had a crack at using the R-TRK and R-PTN settings last night. On the plus side, it works hand in glove with my BOSS DR-550 drum machine, as one would expect. On the minus side, programming drums 1 measure at a times can be very tedious! A simple pattern clone feature would have been a great addition. Aside from that, it's quite intuitive and adds another layer of sounds (and complexity) to the MIDI/modular hybrid!
Ben Asaro
Postby Adam Inglis » Fri Jul 19, 2019 1:09 am
Yeah, the Rhythm Track editing is a bit clunky, but the Rhythm Pattern writing is really quick if you use a sustain pedal with your keyboard controller - it erases whatever note you are holding down.* This way you never have to drop out of record, you just build it up while looping, and if it get's too messy or busy, just hit the pedal and hold the notes to make some space or start over.
And you do know you can copy rhythm patterns of course (just gotta get used to those key commands). This allows you to do the following to speed up the rhythm writing process:
Write a "Rhythm Track" quickly by entering Write and hitting... [Enter] [1] [Enter] a bunch of times to put Rhythm Pattern 1 in the track (you can use the Edit Copy commands if you need to extend this further). Now in Rhythm Pattern write, copy pattern 1 to somewhere else and keep editing or tweaking Pattern 1. When you get something you like, copy it again and then erase or tweak Pattern 1. You're basically using Pattern 1 as an edit buffer, without having to mess around with changing the Rhythm Track. This way you can test your patterns against the rest of the music. After a while, you'll have a bunch of patterns saved that you can then sequence into a Rhythm Track.
*on the MC-50 at least. The "Super MRC" operating system is almost identical in it's implementation on the 500, so I would expect it to work there as well. There is a manual called Super MRC Advanced Course that would detail this, however I can't find it on the webs, just the Basic Course. The MC-50 manual explains it.
Adam Inglis
Adam Inglis
Semi-Automatic
Funboys
