What do I need to do so that two computers can use one Serial device.
Postby JayFlex » Mon Jun 10, 2019 9:41 am
I'm talking about Roland, connected via Serial. It would not be desirable to poke the connector every time here and there, and how to make it so that two computers could use it. By the way, not necessarily at the same time. Can take it turns, just to avoid physical connect/disconnect.
With Midi everything is clear. buy midi interface and the problem is solved. And here how to be? Serial splitter/hub or what is it called at all? Or KVM on COM?
JayFlex
Re: What do I need to do so that two computers can use one Serial device.
Postby BJG145 » Mon Jun 10, 2019 11:17 am
Serial switch...? Plenty on eBay / Amazon...
Postby Fixedroad99 » Mon Jun 10, 2019 11:28 am
surest step to burn ports
Better as a software, serial over ethernet, a host is placed on one computer, clients are connected to another, and a network connects ... the client provides a virtual com port for applications
Fixedroad99
Postby Eddy Deegan » Tue Jun 11, 2019 6:30 am
JayFlex wrote:I'm talking about Roland, connected via Serial
Fixedroad99 wrote:Better as a software, serial over ethernet, a host is placed on one computer, clients are connected to another, and a network connects ... the client provides a virtual com port for applications
SoE is useful in cases (I've seen it used in the physical security industry which is riddled with decades-old devices using all kinds of weird serial connections) but given the OP mentioned a Roland device I suspect it wouldn't be useful in this context.
A simple serial selector switch should be fine. I used one for years back in the 90s to share a modem between two PCs.
Some of my musical works.
Postby wireman » Wed Jun 12, 2019 6:56 pm
Maplin? - gone,
Misco? - gone.
Betterbox? still around...
https://www.betterbox.co.uk/products/auto-scsi-manual/manual
wireman
