Case for small portable rig?
PostPosted: Sat Nov 09, 2019 4:56 pm
by Arpangel
I've put together a small portable traveling set-up, comprising of an Alesis Micron, a Mackie 1202 VLZ4 mixer, a couple of effects pedals, volume and sustain pedals, plus all requisite leads and headphones.
An aluminium case to fit the Micron and the mixer is a bit too cumbersome, for this I might have to build something as it needs to be the right size and no bigger. But I'm wondering about off-the-peg stuff? I'm maybe thinking of suitable sized back-packs that will hold everything nice and securely, as they are light, I can't think of anything else that won't add lots of weight be bigger and be awkward to carry.
PS, I've just been looking at the amazing Radial Key Largo, it has everything I need, and is smaller than the Mackie mixer, so that could save a bit of space.
Re: Case for small portable rig?
PostPosted: Sat Nov 09, 2019 7:11 pm
by Dave B
I think that you are on the right lines with a backpack. Some of the larger ones are designed to hold 2 laptops plus odds and ends so should be able to hold your kit. I have one that I got from work which is tough as well - Kevlar iirc
PostPosted: Sun Nov 10, 2019 8:46 am
by Arpangel
Dave B wrote:I think that you are on the right lines with a backpack. Some of the larger ones are designed to hold 2 laptops plus odds and ends so should be able to hold your kit. I have one that I got from work which is tough as well - Kevlar iirc
Thanks Dave, I'm going to go along to a shop with the measurements of the Micron, the biggest thing, I've found a very small Behringer mixer that'll replace the heavy and larger Mackie, and the Berry is only £40, as opposed to the Radial, which is £400
PostPosted: Sun Nov 10, 2019 10:38 am
by DGL.
I haven't looks but would be surprised if Thomann didn't have something designed for this task.
PostPosted: Sun Nov 10, 2019 12:48 pm
by Arpangel
DGL. wrote:I haven't looks but would be surprised if Thomann didn't have something designed for this task.
I've been thinking about a small lightweight keyboard case, like an SKB type thing, but things will rattle about inside.
Trouble with a back-pack is that the Micron would have to be carried vertically, and that's a big back-pack! And, it's not really necessary as most of the time I'll be going in a car.
Im going to try a small keyboard bag for the Micron, and the rest can can go in a foam lined case, something like a Pelican maybe.
Oh dear, my my, these first world problems..... :)
PostPosted: Sun Nov 10, 2019 1:40 pm
by Arpangel
Thanks, and they have!
https://www.thomann.de/gb/stairville_sb_144_bag_760_x_350_x_350_mm.htm
It's just the right size for the Micron, and the other bits and pieces.
