Roland PK-5/PK-5A - differences?
Postby The Elf » Sun Nov 10, 2019 3:17 pm
Does anyone know what the differences between these two bass pedal models are?
Re: Roland PK-5/PK-5A - differences?
Postby Wonks » Sun Nov 10, 2019 3:35 pm
Looking at the manuals, the only real difference listed seems to be that the PK-5 just does program change numbers (1-128) whilst the PK-5A can also produce MSB and LSB bank change messages.
Postby Hugh Robjohns » Sun Nov 10, 2019 3:36 pm
Not sure..l I read that the 5a can transpose in poly mode whereas the 5 can't...
Here are their respective manuals:
https://static.roland.com/assets/media/pdf/PK-5_OM.pdf
http://www.synthmanuals.com/manuals/roland/pk-5a/owners_manual/pk-5a_om.pdf
Postby Wonks » Sun Nov 10, 2019 3:57 pm
Can't see any mention of Transpose in the PK-5, so that may be unique to the PK-5A. this seems reinforced by the markings on the front panel as the last pedal on the right on the PK-5 has no Transpose legend, whilst the PK-5A does.
So Bank Select and Transpose seem to be the added features.
Postby The Elf » Sun Nov 10, 2019 4:48 pm
Thanks, guys. Roland themselves say that both can transpose over 9 octaves.
Can't say I'd be likely to have it issue patch changes anyway...
I used to have the 5A and sold it. I've acquired a 5 recently.
Postby Wonks » Sun Nov 10, 2019 5:01 pm
That's whole octave transposition, not the ability to go up or down by x semitones, which is PK-5A only.
Postby The Elf » Sun Nov 10, 2019 5:32 pm
Ah, I see. Again, not something I would be likely to need.
TBH I hadn't realised there were two models, but it seems there's nothing I would rely on to concern me.
