Alesis Photon X25 firmware?
Re: Alesis Photon X25 firmware?
Postby merlyn » Fri Jun 26, 2020 2:53 am
hapciu wrote:I understand the procedure for updating the firmware is to be done in XP but prior to that, I can't erase the actual firmware which is 1.3
The firmware in the zip file linked to above is v1.04, so if you have 1.3 it seems unlikely v1.04 would fix it.
Yuri.ko wrote:i have the same problem with the Alesis photon 25, but i can't find the firmware for this model, does anyone have it? pls send help
Here is the Photon25 firmware :
https://drive.google.com/drive/folders/ ... sp=sharing
It's worth bearing in mind what @BillB pointed out : both models will still work with MIDI via a 5 pin DIN. An X25 is a 25 with a built in USB 1.1 audio interface -- I imagine Alesis were thinking it could be a one box solution for using a laptop -- keyboard, some knobs, the AXYZ dome and audio output in one package via one USB cable.
The X25 works on Linux because it's a class compliant device. Does Windows not do that? I'm kind of surprised, but at the same time not. :)
merlyn
Postby Gerson » Fri Jul 24, 2020 12:25 am
Hi i´m new!
merlyn wrote:
Use Linux : This is what I did using the utility dfu-util through the command line. You could make a bootable USB stick with Linux on it and use that..
How did you did this ? Any Tutorial ?
Thanks!
Gerson
Postby Gerson » Fri Jul 24, 2020 10:51 pm
I solved by making a portable Win XP pendrive and then installing de DFU drivers! thanks for the information! Your posts were very usefull!
Gerson
Postby BillB » Sat Jul 25, 2020 9:29 am
Gerson wrote:I solved by making a portable Win XP pendrive and then installing de DFU drivers! thanks for the information! Your posts were very usefull!
Welcome to the SOS Forum, and thanks for sharing your solution, Gerson. Did you follow any particular guide to create the XP drive that you could share with us?
BillB
