Roland PC-200 Mk II MIDI/Select stuck
Postby PeterPJ » Sat Jan 11, 2020 6:02 pm
Hello, I am trying to connect my old Roland PC-200 Mk II to my Mac via a Roland UM-ONE USB/MIDI interface. I have successfully managed this before, but now I don't seem to be able to get it to work.
When I initially switch the keyboard on I can see input lights on the interface when I hit a key, but, after a short while (less than a minute) the MIDI/SELECT light on the keyboard comes on and I then don't get any indication on the interface.
Even before the MIDI/SELECT comes on, I don't seem to be able to get any sound out of the Mac, but clearly the stuck MIDI/SELECT is the first problem to sort out.
I would be grateful for any help. Anyone experienced this before?
PeterPJ
Re: Roland PC-200 Mk II MIDI/Select stuck
Postby oceanzero » Sun Mar 29, 2020 10:42 pm
Hello
That's exactly what is happening to me right now :(
My midi select it's also stuck,
First I thought the problem was from the AA batteries, but after I change them and the problem persists :(
Someone found the problem/solution?
oceanzero
