Behringer 2600
Re: Behringer 2600
Postby BillB » Fri Jan 24, 2020 8:53 pm
But what happens if you get hobnob crumbs between the keys?
Oh, sorry - what was this thread about? :crazy:
BillB
Re: Behringer 2600
Postby Folderol » Fri Jan 24, 2020 9:41 pm
Martin Walker wrote:Thank you for those kind words Wonks, and thanks also to Hugh for the Amazon link to the keyboard with number keypad - my only remaining proviso is that I'm used to chiclet keys, and I expect that the mechanical keys may be too loud for me ;)
Loud is good! That way everyone knows you're busy being creative and must under no circumstances be disturbed.
That's, everyone in the nearest four houses :)
Re: Behringer 2600
Postby Eddy Deegan » Fri Jan 24, 2020 10:28 pm
I ordered one of each. Shorter one for the DAW to fit alongside the MIDI controller keyboard, full size for my work laptop. I like laptop keyboards but I like the proper clunkers more. If it's good and clicky I might sample the noise, play around with it a bit and try make a rhythm track from the results :D
Some of my works.
Re: Behringer 2600
Postby Folderol » Fri Jan 24, 2020 10:58 pm
Ha!
It's variable clicky :bouncy:
Press softly and you hear the click cleanly. More enthusiastically results in a rattly sound.
Re: Behringer 2600
Postby ManFromGlass » Fri Jan 24, 2020 11:00 pm
and spill resistant!
As yesterday I knocked over an entire glass of lemonade onto a drum which then ran onto the carpet. Why not the uncarpeted part of the floor?
The good news is that it wasn’t a happy hour whiskey. :eh:
Re: Behringer 2600
Postby ManFromGlass » Fri Jan 24, 2020 11:01 pm
Folderol wrote:Ha!
a good way to test if all fingers press with the same force!
Or in my case, if both fingers do.
Re: Behringer 2600
Postby Wonks » Fri Jan 24, 2020 11:35 pm
Show off!
Re: Behringer 2600
Postby Arpangel » Sat Jan 25, 2020 12:15 pm
As I thought, it’s tackier than the Korg, which looks stunning. I think I'll hold out for more Korgs.
Re: Behringer 2600
Postby IAA » Sat Jan 25, 2020 12:33 pm
and do you know something we don’t?? I thought that was it. Most suppliers are saying that in three UK at least.
IAA
Re: Behringer 2600
Postby Arpangel » Sat Jan 25, 2020 12:48 pm
Yes, I know, shame isn’t it, and a bit ridiculous.
May be they are making it as a bit of a PR exercise, and it’s not a money maker.
Re: Behringer 2600
Postby IAA » Sat Jan 25, 2020 8:26 pm
It is, I was nearly there.......but missed. Ah well maybe the Behringer will get the sound, the others are pretty close according to most respected users (including some in this parish), I’d be pretty happy with that.
IAA
Re: Behringer 2600
Postby Eddy Deegan » Sun Jan 26, 2020 9:20 pm
Arrived today, typing on it now... the clickiness is great. The feel is positive and chunky plus it has a really nice power-on sequence with a parade of animated LED light-ups in different colours that reminds me of being in an 80s amusement arcade.
I think it's brilliant. Heartily recommended if you're after that 'proper' old-school full-travel keyboard feel and are able to work in a space that doesn't have anyone within earshot! I will concede it is very loud in operation and doesn't sound dissimilar to a real typewriter (but I like that).
Doing a quick typing test my WPM increased by 8 over the laptop keyboard as well. Bonus :tongue:
Some of my works.
Re: Behringer 2600
Postby Folderol » Sun Jan 26, 2020 9:36 pm
I find mine don't seem to collect crud like some others do :)
Re: Behringer 2600
Postby Eddy Deegan » Sun Jan 26, 2020 11:32 pm
Folderol wrote:It's here.
Yes I do use that shop when I can't find what I want anywhere else :(
Should be arriving Tuesday, it's just that the other one arrived first. I've been meaning to replace my computer keyboards for a while so the thread was timely in that regard, and having one without a numeric keypad is quite desirable too :D
Some of my works.
Re: Behringer 2600
Postby blinddrew » Sun Jan 26, 2020 11:34 pm
Psst. It's supposed to be a forum about the other kind of keyboard.
Just sayin' ;)
Re: Behringer 2600
Postby Eddy Deegan » Sun Jan 26, 2020 11:52 pm
blinddrew wrote:Psst. It's supposed to be a forum about the other kind of keyboard.
Just sayin' ;)
Good point - and I've got a couple of those too! ;)
Some of my works.
Re: Behringer 2600
Postby Folderol » Mon Jan 27, 2020 1:57 am
Talking of which, I had an unpleasant surprise with my QS300 the other day - very uneven response from aftertouch :(
Although Yoshimi doesn't use it directly, it can be MIDI-learned, so I was experimenting with routing it to filter cutoff, only with many of the keys it's virtually full on or off :(
Looks like I need to get something a bit better.
Re: Behringer 2600
Postby Wonks » Mon Jan 27, 2020 10:13 am
Folderol wrote:Talking of which, I had an unpleasant surprise with my QS300 the other day - very uneven response from aftertouch :(
Have you checked the velocity curve selection? Part of the utility menu options. Bottom of Pg 188. https://europe.yamaha.com/files/downloa ... S300E1.pdf
Re: Behringer 2600
Postby Folderol » Mon Jan 27, 2020 10:27 am
Normal velocity behaviour is fine. It's only aftertouch that's the problem, and it's not the same across all keys. It seems to be worse in the middle region of the keyboard, so I'm wondering if the pressure sensing is worn.
Users browsing this forum: klaninga
