Lifeforms SV-1 help
Lifeforms SV-1 help
Postby synth182749 » Wed Jan 29, 2020 5:56 pm
I just got a lifeforms sv-1 for my eurorack. Works great apart from the frequency knob on oscillator 1 doesn't change the pitch at all, the sound just stays at the same frequency. However, if I twist it all the way left or right the sound cuts out, so I know it must be connected to the circuit board in some capacity.
Does anyone have any ideas on how fix this?
synth182749
Re: Lifeforms SV-1 help
Postby Ben Asaro » Thu Jan 30, 2020 6:27 pm
Did you buy it new or used? Are you sure you have enough power available for the SV-1?
Ben Asaro
Postby synth182749 » Thu Jan 30, 2020 6:42 pm
Ben Asaro wrote:Did you buy it new or used? Are you sure you have enough power available for the SV-1?
It was B stock, so should be working fine. Think I have enough power as every other aspect works great, including the frequency on oscillator 2 and the LFO.
perhaps it could've been damaged in transit
synth182749
Postby Ben Asaro » Thu Jan 30, 2020 10:02 pm
That's kinda what it's sounding like to me as well. I would unplug a couple of modules and try it again just to verify that it's not a power draw issue.
Ben Asaro
Postby synth182749 » Thu Jan 30, 2020 10:06 pm
Ben Asaro wrote:That's kinda what it's sounding like to me as well. I would unplug a couple of modules and try it again just to verify that it's not a power draw issue.
yep, it's my first module actually
ill contact the supplier
Thanks anyway :)
synth182749
Postby Ben Asaro » Fri Jan 31, 2020 12:04 am
Oh, what a bummer! Hope it gets sorted!
Ben Asaro
Postby Arpangel » Fri Jan 31, 2020 1:31 pm
Before you send it back, ask on the Muffwiggler Forum, if you haven’t done so already, SOS is great, but Muff's is it for anything modular.
Postby synth182749 » Fri Jan 31, 2020 1:48 pm
Arpangel wrote:Before you send it back, ask on the Muffwiggler Forum, if you haven’t done so already, SOS is great, but Muff's is it for anything modular.
Ah, thanks for the advice! I'll check it out :)
synth182749
