A couple of questions about Poly aftertouch
Page 1 of 3
PostPosted: Tue Mar 10, 2020 5:59 pm
by Folderol
Is it normal (or even desirable) to have both channel and poly aftertouch available at the same time?
Also, should polyAT availability and type be the same over the whole instrument, specific to an incoming channel, or specific to a part/instrument regardless of what channel it is on?
Re: A couple of questions about Poly aftertouch
PostPosted: Tue Mar 10, 2020 6:31 pm
by desmond
Folderol wrote:Is it normal (or even desirable) to have both channel and poly aftertouch available at the same time?
it's usually one or the other, as otherwise they will interfere, even if they are controlling different things (ie, pressing one key would always generate both channel and poly touch together).
Folderol wrote:Also, should polyAT availability and type be the same over the whole instrument, specific to an incoming channel, or specific to a part/instrument regardless of what channel it is on?
It's a channel message, so it should have a MIDI channel, and only apply to notes on that channel - unless your instrument doesn't care about the MIDI channel, like some plugins.
PostPosted: Tue Mar 10, 2020 9:07 pm
by Eddy Deegan
+1 to what Desmond said!
1) Poly or Channel, not both
2) PolyAT is per-Voice per-Channel
PostPosted: Tue Mar 10, 2020 10:52 pm
by blinddrew
One of these days I'm going to have to read up on what PolyAT actually is.
Just so I can poke The Elf about it next time I see him of course...
PostPosted: Tue Mar 10, 2020 11:19 pm
by Martin Walker
blinddrew wrote:One of these days I'm going to have to read up on what PolyAT actually is.
In a word - Bladerunner!
Here's Vangelis to explain ;)
https://www.youtube.com/watch?v=zoEkyBX7qsg
PostPosted: Tue Mar 10, 2020 11:37 pm
by Hugh Robjohns
You play a chord, you press one (or more) note(s) harder, and stuff happens to that (or those) note(s) -- stuff like vibrato, filter brightening, volume increase... Or whatever you want to happen to make individual notes 'sing' as you play. It's incredibly expressive, and very addictive!
PostPosted: Wed Mar 11, 2020 9:19 am
by blinddrew
I thought it might be something like that. :)
PostPosted: Wed Mar 11, 2020 9:58 am
by The Elf
The best instruments are always capable of responding to both poly and channel AT all the time, with no need to change any settings. A good example is the Novation Peak.
PostPosted: Wed Mar 11, 2020 10:16 am
by BJG145
The Elf wrote:A good example is the Novation Peak.
My initial thought had been that an instrument would only respond to one or the other at any given time, but I don't see why you shouldn't have both, with one effect responding uniformly to the current maximum keypress, and another responding individually on a note basis. Is that what the Peak can do...?
PostPosted: Wed Mar 11, 2020 11:58 am
by Folderol
So basically, this is a non-standard standard :roll:
The current situation for Yoshimi is that Chan AT is not directly implemented, but is made available for MIDI learning to any control of any part (or group of controls/parts).
In the development version on github, 'master' does Poly AT for filter cutoff (works nicely with brass sounds), and we are planning to enable a range of other options.
PostPosted: Wed Mar 11, 2020 12:00 pm
by The Elf
Folderol wrote:So basically, this is a non-standard standard
Roland XV-5080, Integra-7, JP-80, Novation Peak and Summit all work exactly the same way I've described. So does the ME80 CS-80 emulation. If there's any 'standard', I reckon this is about it.
PostPosted: Wed Mar 11, 2020 1:17 pm
by desmond
It's usually one or the other, as otherwise they will interfere, even if they are controlling different things (ie, pressing one key would always generate both channel and poly touch together).
If this wasn't clear, I was really referring to keyboard instruments *transmitting* channel or poly AT - they don't generally do both at the same time.
As far as *receiving* MIDI AT, then as usual on a synth, the user/patch should decide if either mod sources do something or not.
PostPosted: Wed Mar 11, 2020 6:45 pm
by Folderol
Still puzzling through this. What about multiple actions? For example would someone want to do something like a pitch bend and a vibrato effect at the same time?
P.S. Just added pitch bend to my local copy :)
PostPosted: Wed Mar 11, 2020 6:47 pm
by Hugh Robjohns
Yes, of course... But that's just sharing the Poly-AT modulation control signal to multiple effects destinations, surely, which is a perfectly normal requirement?
PostPosted: Wed Mar 11, 2020 7:28 pm
by Folderol
Questions might seem a bit simplistic, but please bear in mind I've never even touched an instrument with polyAT, and as I'm trying to design this in, I want to be as clear as possible.
