Pedal board chaos.
Pedal board chaos.
Postby Arpangel » Mon Mar 23, 2020 5:17 pm
I’ve got into buying too many pedals, and connecting them up is becoming a nightmare.
I need to have all my pedals available to my two synths at any time, or completely bypassed, to preserve the tone of the dry synth if needed.
At the moment I’ve got a couple of pedals connected to the aux sends of my mixer, and some others permanently connected to my synths, which isn’t ideal.
To avoid constant re-patching, and to have everything available I need something else, but what? Is there a pedal board that can mix, and patch lots of different pedals, or am I going to have to make a patch-bay just for my pedals?
Re: Pedal board chaos.
Postby Sam Spoons » Mon Mar 23, 2020 5:33 pm
Postby zenguitar » Mon Mar 23, 2020 5:34 pm
Boss make several programable FX loops/switchers. Might be worth checking if any of those suit your needs.
https://www.boss.info/uk/categories/acc ... switchers/
Yogi Berra
Postby Arpangel » Mon Mar 23, 2020 6:12 pm
Thanks, but these Boss units I notice, have only two inputs.thats not enough for my synths.
I’m thinking it’s probably best to build a small patch bay, but I’m still not sure.
Postby Hugh Robjohns » Mon Mar 23, 2020 6:18 pm
How is a patchbay going to 'avoid constant re-patching'? :think: ;)
Postby Arpangel » Mon Mar 23, 2020 6:33 pm
Hugh Robjohns wrote:How is a patchbay going to 'avoid constant re-patching'? :think: ;)
Not having to move pedals around, from synth to synth, crawling around on the floor under table etc.
I’m finding also that a lot of peals because of their nature, really do degrade a signal, even in bypass. I know it’s going to end up with me buying yet another big mixer with loads of aux sends, just what I didn’t want to do, I can’t think of anything else that’s going to give the flexibility.
Postby zenguitar » Mon Mar 23, 2020 6:37 pm
It's worth downloading the pdf manuals for the Boss units and double checking. They can be configured to work so that some effects are before the amp and others inserted in the amp FX loop. So it may be possible to use one of the loop inputs as an additional instrument input.
And don't forget that you can also put an A/B (or A/B/C) switch before the input to switch between multiple instruments.
Yogi Berra
Postby Arpangel » Mon Mar 23, 2020 6:41 pm
zenguitar wrote:It's worth downloading the pdf manuals for the Boss units and double checking. They can be configured to work so that some effects are before the amp and others inserted in the amp FX loop. So it may be possible to use one of the loop inputs as an additional instrument input.
Thanks, yes, this requires careful working out.
Postby Arpangel » Tue Mar 24, 2020 6:19 pm
It’s got to be just a bog standard patch bay, I’ll only need one, it’ll solve all of my problems in the cheapest possible way.
I can wire all of my pedals to it, and my synths, I know I’ll still be patching, but it will be really flexible, and won’t require total re-patching and crawling around on the floor.
Postby al_diablo » Sat Mar 28, 2020 12:47 am
I'm pretty sure a gigrig g2 would do exactly what you want
https://www.thegigrig.com/g2
Plus they make input switching units that chain so you can alternate between multiple inputs
al_diablo
Postby ManFromGlass » Sat Mar 28, 2020 3:13 am
I'm in a similar situation where a mixer with quite a number of sends might make the most sense. But then I also like the idea of chaining the pedals so maybe a patch bay is better. I'm not going into an amp but need stereo out into the computer.
Some of my pedals are in and out mono, some are in and out stereo, some are mono in but stereo out, one crazy one, Lexicon Vortex, reacts differently if you send it mono or stereo, but it is stereo out.
Following this thread with interest.
Postby Arpangel » Sat Mar 28, 2020 9:30 am
ManFromGlass wrote:I'm in a similar situation where a mixer with quite a number of sends might make the most sense. But then I also like the idea of chaining the pedals so maybe a patch bay is better. I'm not going into an amp but need stereo out into the computer.
I’ve actually gone down the mixer route, I’ve got a cheap AntMix 1204FX, it has two aux sends, plus a sub group that I can also use as sends, so I’ve basically got four aux's there.
A couple of pedals are in-line with my synths, so that’s all that solved for now, until a I get more pedals! :shocked:
I’m lusting after a Specular Tempus, and an EHX Ring Thing, and about another five EHX pedals in general!
Postby ManFromGlass » Sat Mar 28, 2020 1:09 pm
The Pedal Acquisition Syndrome is an intense and expensive sub-branch of GAS!
There is no cure yet although I’ve tried Feigned Indifference and hiding my credit card - with no luck
I keep going back the YouTube’s from Chase Bliss, Red Panda and the Quebec, Canada company, is that the still water one?
:smirk:
