Reaching the Summit
Re: Reaching the Summit
Postby BillB » Sun Mar 29, 2020 12:49 pm
Enjoy Malc wrote:That’s a shame if it's limited. In the Summit manual, there’s not even mention of general oscillator panning, ie is it possible to pan osc 1, 2 and 3 separately? Surely the two synths within the Summit are pan-able?
I only see a parameter for unison voice spread. Does this also apply to voices in ordinary polyphonic modes? Like the DSi pan spread?
It is not generally possible to pan individual oscillators on a synth, as that would require the following stages (filter/amp) to be stereo. The Waldorf Blofeld does, however, allow the outputs of its two filters to be panned, so there is a range of approaches.
As for the Summit / Peak, both manuals say:
Note that UniSpread is still effective even with unison voices set to 1: in this case, a single note played is positioned centrally in the stereo image, while playing multiple notes results in left or right panning, depending whether the voice in use is odd- or even-numbered. When used like this, best results are obtained with moderate amounts of Unison Spread.
So yes, it should work for polyphonic modes and add some stereo variety to the sound.
BillB
