MIDI IN Korg Microkorg (original)
Re: MIDI IN Korg Microkorg (original)
Postby Arpangel » Thu Apr 02, 2020 5:37 pm
BillB wrote:
Arpangel wrote:This is strange, I’m looking forward to the explanation!
:think:
So's Charic!
It has got me stumped. Wish I had a mini mighty MicroKorg here and we could meet on Zoom and compare settings.
But I don't :headbang:
If I had the same problem I would probably run the MK MIDI Thru into a MIDI monitor (e.g. MIDI-OX on PC, MIDI Wrench/ MIDI Scope on the iPad to look at the MIDI data and check its actual channel.
I'm pretty sure it is down to settings on the MK, but Charic has done a factory reset, tried a variety of Ins and Outs and been over the manual - as have I. So I don't know what to suggest.
I bet it’s one of those pesky obvious things that we all overlook sometimes, let’s hope.
You do have to make sure you turn local control off to play from an external keyboard, I’ve never come across this before, it’s a bit confusing, normally IME it shouldn’t make any difference if local is on, or off, synths just play okay, but apparently not in the Korg's case.
Postby Wonks » Thu Apr 02, 2020 6:02 pm
If it's a proper hardware MIDI Through port (rather than a software driven one), then it may be that there's a fault, maybe just a dry joint, on the, MIDI input to the Korg itself. So the hardware link between the MIDI ports is passing on incoming messages, but a faulty component is stopping the Microkorg from seeing and responding to them.
Postby BillB » Fri Apr 03, 2020 12:54 am
Interesting call, Wonks, good out-of-box thinking (in-the-box thinking?). It has me wondering about any way of establishing whether there is any MIDI input at all. I wondered about sending a data dump into the MK (did you do that, Charic?) but the manual doesn’t say whether the display registers receipt of a data dump in any way.
So, last suggestion. With Local On, establish that the MK is making a sound when you press the keys. Now turn Local Off and plug the MK MIDI Out into its MIDI In - any sound?
Oh, one more, can you use clock data from any MIDI source to set the speed of the arpeggiator on the MK? The Global setting is important here.
BillB
Postby charic » Fri Apr 03, 2020 2:44 am
Cheers guys for your patience yet again.
BillB.... in answer to your Question "So, last suggestion. With Local On, establish that the MK is making a sound when you press the keys. Now turn Local Off and plug the MK MIDI Out into its MIDI In - any sound?"
....Sound established, but No Sound with local off.....
Also today (all day) tried more things but to no avail) then discovered on my MacBook an app called Audio Midi Setup!
Tried it, didn't work, so swapped out the microKORG and replaced it with the Novation MiniNova and it worked?
If I mouse click the down arrow/triangle the Mininova makes a sound ( all be it random with each mouse press) then when I press/play the keyboard the up triangle illuminates, and although the Novation icon itself is still greyed out, the 2i4 is illuminated, the MicroKorg is connected to the 2i4 and the responses from the test are there.
I don't get the down triangle illuminated for the microKorg, suggesting no Midi-IN.
Thank you guys for your help on this on. I'm going to leave this for a while, until I can get myself back to Glasgow, or possibly Aberdeen, see if a shop specialist can connect this keyboard and either tell me what I'm doing wrong, or to satisfy my assumption and just confirm, the MIDI-IN port on my Korg is shot somehow :problem:
charic
Roland Juno D Limited Edition
Arturia Keystep
Novation Impulse61
Novation MiniNova
Korg MicroKorg
Focusrite Scarlet 2i4
Edirol M-10DX.
KRK Rocket 5 G3
Audio Technica MTH-M50x
Postby Arpangel » Fri Apr 03, 2020 6:21 am
charic wrote:Cheers guys for your patience yet again.
Surely, you wouldn’t expect the Korg to make a sound with local off, nothing would appear at the Midi out, because local is off! It’s not generating any data itself.
Have you just tried setting local off, while connecting an external keyboard?
Postby BillB » Fri Apr 03, 2020 8:55 am
Arpangel wrote:Surely, you wouldn’t expect the Korg to make a sound with local off, nothing would appear at the Midi out, because local is off! It’s not generating any data itself.
Local off disconnects the keyboard's MIDI from the internal sound generation engine, but should still produce a MIDI signal at MIDI Out. So if this is connected directly to MIDI In (as opposed to going through a DAW), it should generate a sound. My thinking was that the output/input MIDI channels would probably be the same, so it might remove that issue.
Oh well. Charic, did you try the Data dump and Arp speed tests that I suggested? Leaving notes aside, I am trying to establish whether any signal is getting from the MIDI input to the synth engine (which is Wonk's point explored).
BillB
Postby charic » Fri Apr 03, 2020 7:53 pm
Local ON /OFF works as it should. Still no sound when played from external device.
Not yet tried the Data dump or ARP test, but have installed MIDI OX (W10 Version) and there does appear to be data on both ports, but the microKORG itself is not listed in midi devices, just the 2i4 audio interface, but that's normal, and when I play notes from the mKORG I see data in the Monitor - Output screen, and similar in the Monitor - Input screen, but otherwise the Input screen is just scrolling the timestamp.
That's how I interpret the data. Gotta find somewhere to stash an image then link the URL here.
charic
Arturia Keystep
Novation Impulse61
Novation MiniNova
Korg MicroKorg
Edirol M-10DX.
KRK Rocket 5 G3
Postby Arpangel » Sat Apr 04, 2020 8:40 am
Hope you get it sorted, be interesting to know what it is!
Postby charic » Mon Apr 13, 2020 11:43 am
Had a peek inside to see if there's anything loose at the point where the midi terminals contact the circuit board,but I'd still need to remove the board to reach/inspect the far side.
Gonna leave the Korg a while, and just maybe, next time I'm in the big city, I'll try get it connected in-store.
charic
Arturia Keystep
Novation Impulse61
Novation MiniNova
Korg MicroKorg
Edirol M-10DX.
KRK Rocket 5 G3
Postby charic » Sun Nov 29, 2020 3:29 pm
I said I was going to leave this for a while and due to the COVID restrictions and work, Ive just not had the time to drive the 8 hour return trip to Glasgow to let a 'professional' possibly take a look ?
Today however, I've tried again,
3 Devices, Novation 61 controller, Juno-D LE, MicroKorg.
In addition to following the BASIC instructions from the Korg manual, this is what I have tried today.
1). Juno Midi-OUT to Microkorg Midi-IN (Both channel 1) then AUDIO out 1/4" from Juno into Korg input-2. Then setup Korg's menu OSC to AUD (audio) then run another 1/4" Korg audio out to Speaker, Roland KC60.
When I play the Juno, nothing happens?
2). If I reverse the cable direction ie. Korg-OUT to Juno-IN. I can play the Juno using the Microkorg. So the Midi Output works on the Korg but not the input?
3). If I then Midi Out from Novation 61 to Korg Midi-In then Midi-Through from the Korg into Juno, that works! I can play the Juno from the Novation via the Korg, therefore the Korg's MIDI-IN must be working?
Fact is, I cant use any external ( preferably larger keyboard ) at present to play the Microkorg which is rather annoying, since the Midi manual says it's possible.
It's still possible the fault is mine alone, but there's only so much you can try before you come to a conclusion.
charic
Arturia Keystep
Novation Impulse61
Novation MiniNova
Korg MicroKorg
Edirol M-10DX.
KRK Rocket 5 G3
Postby BillB » Tue Dec 01, 2020 6:41 pm
BillB wrote:Charic, did you try the Data dump and Arp speed tests that I suggested? Leaving notes aside, I am trying to establish whether any signal is getting from the MIDI input to the synth engine (which is Wonk's point explored).
BillB
Postby charic » Sun Jan 10, 2021 8:23 pm
Sorry BiLLB for the late reply.
The Korg has been stored up in the loft since my last attempt.
Given all my attempts so far, with no result, I'm sure the Midi IN is still at fault 'somewhere" but because Midi THRU through works ( assuming data is passed via Midi IN ), then Im still baffled?
Full lock-down is preventing any travel arrangements to have the device examined in a pro music store, but I will try a sysex data dump into the Korg sometime this Month to further assess the Midi IN socket.
Last minute thought, would the routing for the data dump differ much to that of the the sound module? I suppose it could, and If so, could narrow down the fault even further.
I see your point, and should try sooner than later.
charic
Arturia Keystep
Novation Impulse61
Novation MiniNova
Korg MicroKorg
Edirol M-10DX.
KRK Rocket 5 G3
Postby BillB » Sun Jan 10, 2021 9:35 pm
Well, if you can do a successful data dump, the issue is likely around the sound generation settings, not the MIDI in. If you can't do a data dump, the issue is more likely how far the MIDI In signal is getting, accepting that it makes it as far as MIDI Thru, which is likely a direct electrical connection without any processing.
BillB
Postby charic » Sun Jan 17, 2021 11:53 pm
I've just installed the microKORG Sound Editor, and Focusrite 2i4 drivers on my W10 pc.
In the Sound Editor under settings - midi devices, i see that the Focusrite USB Midi is detected for both Midi IN & OUT.
The MicroKORG connection is midi OUT to focusrite IN and focusrite OUT to IN on the KORG.
When i start the sound editor, a small window appears, titled "midi transferring" then i get an error warning, No Device Found, Check MIDI device setting.
The Micro KORG was factory re-stored, write protect off, second attempt, same result.
Further more, I then used MIDI-OX and was able to download sysex data from the Korg to my pc, but sending the SysEx back failed.
It appears to start, various lights blinking on the KORG but then i receive an on-screen warning, SysEx: No Buffers Available, Not enough memory, quit some apps?
charic
Arturia Keystep
Novation Impulse61
Novation MiniNova
Korg MicroKorg
Edirol M-10DX.
KRK Rocket 5 G3
Postby zenguitar » Mon Jan 18, 2021 12:01 am
Is there an option to send the MIDI data at a slower rate?
The original MIDI spec was for 30+ year old hardware. Modern USB can shift data orders of magnitude faster. That can overwhelm the buffers of hardware built to meet MIDI spec.
No guarantees, but always worth a try.
liberté, frivolité et vanité
