The All-New Behringer Keyboards 'n' Stuff Thread
Re: The All-New Behringer Keyboards 'n' Stuff Thread
Postby BJG145 » Thu Oct 29, 2020 9:32 am
Arpangel wrote:Yes, if I did buy one the case would not be an option, it’s a necessity.
Just need to sort out a speaker for you now then, maybe an Onde... ;)
https://youtu.be/KBykTk6Url0?t=17
Postby Arpangel » Thu Oct 29, 2020 9:57 am
Wow! You’re right, two of those speakers and a French Connection would look the business, so no problem then, we’d be up to the cost of a genuine 2600!
:D :D :D :D :D
Postby resistorman » Mon Nov 02, 2020 1:35 am
In case the Behringer 2600 costs too much for you:
https://cherryaudio.com/instruments/ca2600
resistorman
Postby Arpangel » Mon Nov 02, 2020 8:44 am
resistorman wrote:In case the Behringer 2600 costs too much for you:
That’s the trouble, it doesn’t cost enough, I’d rather pay a bit more for the nice spring reverb, handy built in speakers for programming, and above all, it could be the right size, in a case.
I already have the Arturia 2600, it "was" great, until they "upgraded" it, the sound changed, and I lost all of my presets, Arturia have never been good at backwards compatibility, and as for the claimed preset converter, it’s never worked on any computer I’ve owned.
Postby DGL. » Tue Nov 03, 2020 1:49 pm
QSG for the 2600 has low been uploaded, and contains something quite interesting in the reverb section.
NOTE: 2600 uses a digital reverb, while BLUE MARVIN features a real, on-board spring reverb
https://mediadl.musictribe.com/media/PL ... QSG_EN.pdf
Looks like there will be another version of the 2600 with a real spring!, I would guess it has the blue Marvin paint job too.
DGL.
Postby The Elf » Tue Nov 03, 2020 3:19 pm
DGL. wrote:Looks like there will be another version of the 2600 with a real spring!
Postby Arpangel » Wed Nov 04, 2020 9:11 am
DGL. wrote:QSG for the 2600 has low been uploaded, and contains something quite interesting in the reverb section.
Thanks DGL, a real spring would be fantastic, the blue paint job too, it’s my favourite, and might sway me to open my wallet, if I get that case too.
Postby DGL. » Wed Nov 11, 2020 8:12 pm
RD-8 new firmware, 2.0.4, is now live. Update is done via the new SYNTHTRIBE app, once in RD-8 section select update page and click update, the only reboot I needed was once the update was finished, it seems to put the RD-8 in updated mode automatically now which is good.
Behringer RD-8 Firmware Version 2.0.4 (09 Nov 2020)
Bug Fixes:
1. Fixed the issue where MIDI out notes of note repeat were fixed to repeat 8.
2. Fix issue that adjusting swing value while playing may affect MIDI and TRIG SYNC. 3. Improved pattern auto-save. All the below pattern changes will now be auto saved with STEP RECORD on:
3.1. Step on/off by pressing STEP button
3.2. Press TRIGGER to set step on when playing
3.3. Note repeat live record
3.4. Set step on/off in RAND setting menu
3.5. Press STEP in pattern length setting
3.6. Sweep erase by Hold + VOICE button
3.7. Erasing all steps of selected voice by ERASE + VOICE button
3.8. Step copy 1-16 to 17-32 etc.
New features:
1. Lights off for the disabled voice of MUTE/SOLO/BUS SEND, when enabled they turn to solid red/white/pink.
2. Set step off steps to on when in note repeat live recording.
3. Use the 4 red LEDs (1, 2, 4, 8) above the note repeat buttons to show which note repeat value is recorded on a step depending on the voice selected.
4. Add sweep erase function, when playing in STEP MODE, hold TAP/HOLD then press voice button to remove steps from pattern.
5. When in STEP RECORD mode, hold ERASE then press voice button to delete all steps of the voice in pattern.
6. Support pattern changing to different songs while playing.
6.1. Enter SONG MODE
6.2. Hold TAP/HOLD button
6.3. Select Song with step button (1-16) to go to after current pattern has finished
6.4. The song step button you selected will flash white and the others will flash red, now select a pattern
6.5. When pattern is selected, the button will fast flash red until the selected song and pattern starts Note: this will break the song chain playing.
7. Auto save the chain song: in SONG mode with record enabled, press step button to select a chain song for current song, the chain song will be auto saved.
8. Support step size changing while playing.
Note: Updating from older firmware than V2.0.4, you may need to reboot RD-8 manually when asked.
To see the current firmware version:
1. Press SETTINGS.
2. Hold down the TAP/HOLD button while pressing step key 5.
The display will show the current version.
NOTE: PROB and FLAM are only set to off as default for all steps when a full factory reset has been completed (this is so you can keep previous patterns if required):
To reset to default factory settings:
1. Press settings.
2. Hold Tap/Hold and press step key 16.
3. The display will now say Wait.
4. When the factory reset is complete the display will show Done.
5. Now turn the unit on and off to complete the procedure.
Synthtool Updates:
1. Synthtool renamed SYNTHTRIBE.
2. Screen size fixed.
3. Minimize button added and command “W” to minimize supported.
DGL.
Postby DGL. » Wed Nov 18, 2020 9:05 am
An update on the monopoly, shipping to retailers has started and they will announce pricing hopefully tomorrow.
Behringer FB wrote: We're very excited to announce that the MonoPoly is now shipping and on its way to our retail partners.
This wonderful synthesizer was a truly challenging project and has taken longer than we expected. But this musical baby is finally ready and we're very excited to now get this into your hands.
DGL.
Postby ManFromGlass » Wed Nov 18, 2020 2:02 pm
How come the factory photos never show people in them? Are they using gnome and hobbit labour?
Postby desmond » Wed Nov 18, 2020 2:08 pm
There's just one guy in there doing all the work.
And he was the one taking the photo...
Postby Arpangel » Wed Nov 18, 2020 2:25 pm
How about a Poly 61?
Postby resistorman » Wed Nov 18, 2020 2:27 pm
How about an mpe module :bouncy:
resistorman
Postby Hugh Robjohns » Wed Nov 18, 2020 5:00 pm
How about the bloomin' promised DS80! :protest:
Postby Arpangel » Wed Nov 18, 2020 5:56 pm
How about a bloomin Hammond C3?
8-) 8-) 8-) 8-) 8-)
