Korg X5DR to Host
Korg X5DR to Host
Postby DanielBeach » Thu Jul 16, 2020 1:53 pm
Does anybody know if there's somewhere to buy an 8-pin mini din to USB cable? I want to use the connect To Host port on my X5DR to avoid buying an extra midi interface.
Or, is it just easier these days to use regular midi connections?
Daniel
DanielBeach
Daniel Beach
Logic Pro X 10.5, Yamaha MODX8 keys, NI Komplete 12, AmpleSound Guitars, various other software!
Re: Korg X5DR to Host
Postby Rich Hanson » Thu Jul 16, 2020 2:04 pm
You're probably best off just getting a basic USB to MIDI cable, which are quite cheap (between £10 and £15).
If I remember correctly, the To Host port is RS422 on a proprietary connector which would require a USB to Serial adaptor plus the Korg Serial to X5DR cable so you'd likely end up paying more.
Rich Hanson
Postby nickle15 » Thu Jul 16, 2020 2:32 pm
As Rich mentioned, the MIDI to USB cable is a wonderful option. That's currently how my Trinity interfaces with my computer. I've not had any problems with this arrangement and in my opinion it doesn't get any easier to connect "old" gear to modern computers.
nickle15
Postby Eddy Deegan » Thu Jul 16, 2020 2:53 pm
nickle15 wrote:As Rich mentioned, the MIDI to USB cable is a wonderful option. That's currently how my Trinity interfaces with my computer. I've not had any problems with this arrangement and in my opinion it doesn't get any easier to connect "old" gear to modern computers.
That works well if you're connecting a device to a host (the computer being the host in this case).
If you want to connect a device to a device (for example to play the sounds on a Trinity from a USB keyboard controller) then you'll need a USB host box in the middle (or a cable with an inline lump that acts as a USB host).
USB MIDI makes a distinction between the roles at each end of the cable (device vs. host) whereas the old MIDI DIN connections are all treated as straightforward 'in' and 'out' ports regardless of whether they are on a synth, a computer or anything else.
Even though USB demands that one end is a 'host' and the other a 'device' I always felt that the inablity to connect two devices directly together with a simple double-ended Type A cable was something of a glaring omission in the USB MIDI implementation, especially as the ability to control one device from another was pretty much the main reason MIDI was invented in the first place.
Some of my works
Postby SteveFlesh » Thu Jul 16, 2020 3:03 pm
I'd go with the Midi to USB cable option.
I dabbled with the 'to host' ports with my NS5R (the successor to the X5DR) but struggled to get the Korg drivers to install/work on post XP versions of windows.
I recall an eventual workaround which involved a serial to USB adapter and I think a non-korg driver, but I wasn't 100% certain about the stability and midi timing, so ended up using a midi interface instead (as I have multiple midi devices)
SteveFlesh
Postby Sam Spoons » Thu Jul 16, 2020 5:05 pm
Eddy Deegan wrote:Even though USB demands that one end is a 'host' and the other a 'device' I always felt that the inablity to connect two devices directly together with a simple double-ended Type A cable was something of a glaring omission in the USB MIDI implementation, especially as the ability to control one device from another was pretty much the main reason MIDI was invented in the first place.
Is that even possible without some hardware in the middle? I thought, as you say, it was USB that presented the limitation?
Postby The Elf » Thu Jul 16, 2020 5:19 pm
I recently created my own USB-to-USB solution using a pair of Mio cables and some back-to-back barrel DIN connectors. Works fine.
Postby DanielBeach » Thu Jul 16, 2020 7:47 pm
Bizarrely, I never knew that Midi to USB cables existed :-)
That might be the way forward - or a 2x2 interface in case I buy any more second-hand 90s synth modules from ebay :-)
DanielBeach
Daniel Beach
Postby nickle15 » Thu Jul 16, 2020 7:56 pm
DanielBeach wrote:Bizarrely, I never knew that Midi to USB cables existed :-)
If you buy the right MIDI to USB you'll get the added benefit of a little strobe light show included in the cable. What a bonus! :)
nickle15
Postby Sam Spoons » Thu Jul 16, 2020 8:41 pm
Strictly 'midi to USB' cables don't exist, 'midi to USB' interfaces built into a 'line rat' do.....
Postby Rich Hanson » Thu Jul 16, 2020 9:00 pm
There's always one pedant, isn't there :P
(This time it wasn't me)
Rich Hanson
Postby Dashanna » Wed Jul 29, 2020 4:01 pm
So this is old technology - that 8-pin is an old-style serial interface not USB.
I have tried to connect mine with a USB to "D" serial port converter, and then I made a cable up, "D" to 8-pin. Couldn't get it to work.
The only way I could get it to connect was using an old windows laptop with the serial port.
(Old synths need old computers is my go-to maxim.)
I bought an 8-pin to 8-pin lead, and a "D" to "D" lead, and cut them both in two, and connected the wires inside, according to pin-out details online. Incidentally, I have a Roland module that also has the 8-pin to host, but the pin-outs are different to the Korg, so I had to make two. Both companies sold proprietary cables. This is several years ago, and greater detail is forgotten.
The To Host allowed a computer editor to program the synth, while using the MIDI from a keyboard or whatever.
Dashanna
