Synthesis Techniques For Emulating Vintage Sounds
Re: Synthesis Techniques For Emulating Vintage Sounds
Postby ramthelinefeed » Mon Jul 27, 2020 10:29 am
N i g e l wrote:Non - VCO synths with static pitch offsets:
The WASP synth uses a master oscillator which is frequency divided down to produce the note frequency (controlled by a note_number & octave number).
The division is only 8 bit, so the note pitches are not exact.
This is similar to organ technology of the time where note pitches were derived from a master oscillator & a top octave divider IC. This was also used in String Synths and also I think some monosynths too.
I dont know the accuracy of the organ chips in terms of pitch.
That's very interesting, cos I think the synth I own which exhibits this effect most is a Yamaha CS01, which if I recall correctly from the Service Manual, also uses a digital divide-down from a master VCO running in MHz.
ramthelinefeed
A weasel hath not such a deal of spleen as you are tossed with!
Postby N i g e l » Mon Jul 27, 2020 12:57 pm
My Wasp is actually a Jasper; schematics available here :
http://www.jaspersynth.co.uk/wp-content ... ematic.pdf
Top Oscillators are 555 timers, dont know the frequency.
The Jen SX1000 uses an M110 chip which looks to incorporate a keyboard scanner & dividers.
Schematics & MIDIfication projects are available online somewhere
ORGAN chip databook:
http://www.bitsavers.org/components/sgs ... OS_2ed.pdf
Postby Dashanna » Tue Jul 28, 2020 7:05 pm
N i g e l wrote:
[2] modulate the note with the midi note number. Same "error" for a particular note but obviously as the MIDI note number increases the error increases.
Yes! This trick seems to me the most effective for me on my E-mu P2K module. A tiny bit of note number added to the fine pitch, to simulate a not quite accurate range and scale. Especially if added differently to two oscillators (or just to one) meaning that each note will have a consistently different detune character.
On something like the Nord Modular I still use, it is possible to set a sequencer to cycle through a different set of pitch and filter variations on each note - to simulate, for example, an Oberheim poly-synth cycling through voice cards.
But, you could get too caught up in where all this instability is supposedly coming from - really, just a bit of randomness from whatever sources are available is sufficient.
Dashanna
Postby desmond » Tue Jul 28, 2020 7:14 pm
Dashanna wrote:But, you could get too caught up in where all this instability is supposedly coming from - really, just a bit of randomness from whatever sources are available is sufficient.
Yep - which was the point I was making.
Postby ramthelinefeed » Tue Jul 28, 2020 8:52 pm
Yes but your point was wrong because this thread is about something which ISN'T random :headbang:
ramthelinefeed
Postby N i g e l » Tue Jul 28, 2020 11:09 pm
Awesome, id never thought about doing that !
