Polysix Rebuild
Re: Polysix Rebuild
Postby The Elf » Fri Jan 15, 2021 10:41 am
Sounds like there's hope. It will be interesting to follow your progress!
Re: Polysix Rebuild
Postby nickle15 » Tue Mar 02, 2021 8:09 pm
So we finally got into the keyboard parts last night - just to give them a look. I haven't photographed anything yet but will do that once we unpack them for good.
KLM-367 (if I'm looking at everything correctly) is the board that is susceptible to damage from the battery leakage and it appears this one is no exception. We could see where attempts have been made to fix some traces. Time will tell if those attempts were successful. If not I suppose the Kiwisix upgrade would be the next solution since that apparently replaces this entire board (again, if I'm understanding everything correctly) but I will wait on that as it's a significant outlay of cash.
According to the original description I need to replace three switches - one is broken and two are damaged. And we need to replace two chips - one is $5 and one is $100.
All of the buttons are there except for one. Unfortunately not a single knob came bundled with the parts. The seller said he thought he had a bunch of them in his shop somewhere so I'll touch base with him on those because if you're actually lucky enough to find them they're annoyingly expensive. I'm sure there are other knobs that would fit and do the trick but I'd like to bring it back to stock as much as possible.
Also missing is the part of the chassis that houses the pitch and mod wheels - and those wheels are missing as well.
So basically I didn't learn much more by looking at the parts but after several weeks it looks like we're getting ready to ramp it up and that's exciting!
As posted elsewhere in the keyboard forum here we are also tackling a Prophet 600 that is in fantastic condition, besides a series of 8 keys that won't work. So - not sure what gets done first or how quickly, but fingers crossed we have some success with both keyboards.
I'll post more soon!
nickle15
Re: Polysix Rebuild
Postby Dan LB » Tue Mar 02, 2021 9:28 pm
Not sure where you are in the world nickle15 but if you’re in the US, it might be worth contacting Syntaur to help you locate the missing parts you need.
https://www.syntaur.com/
Dan LB
Re: Polysix Rebuild
Postby nickle15 » Tue Mar 02, 2021 9:33 pm
Dan LB wrote:Not sure where you are in the world nickle15 but if you’re in the US, it might be worth contacting Syntaur to help you locate the missing parts you need.
Thanks Dan. I'm in the US and monitor the Syntaur site regularly. They seem like a really decent outfit and they're definitely on my radar. I appreciate the tip!
nickle15
Re: Polysix Rebuild
Postby BJG145 » Tue Mar 02, 2021 9:56 pm
nickle15 wrote:one is $100
...what's that...?
Re: Polysix Rebuild
Postby nickle15 » Tue Mar 02, 2021 10:06 pm
...what's that...?
Sorry - I was just going off some notes my dad had written on a diagram. But it looks like the SSM2044.
nickle15
Re: Polysix Rebuild
Postby Folderol » Tue Mar 02, 2021 10:27 pm
Interesting chip. It wouldn't be easy to emulate that!
Yes. I am that Linux nut.
Re: Polysix Rebuild
Postby BJG145 » Tue Mar 02, 2021 11:13 pm
nickle15 wrote:it looks like the SSM2044
I wondered if it might be. It's possible I might have one; I'll check.
Re: Polysix Rebuild
Postby nickle15 » Tue Mar 02, 2021 11:38 pm
Very cool - thanks!
nickle15
Re: Polysix Rebuild
Postby Dan LB » Fri Mar 05, 2021 3:29 pm
nickle15 wrote: ........it looks like the SSM2044.
There’s somebody local to me selling two of these chips. He wants €45 each for them. If you get stuck and can’t find them in the US I’d be happy to pick one up for you and post it.
Dan LB
Re: Polysix Rebuild
Postby nickle15 » Fri Mar 05, 2021 7:08 pm
Awesome offer and I'll let you know - thanks so much!!
nickle15
Re: Polysix Rebuild
Postby nickle15 » Fri Apr 23, 2021 1:47 pm
At long last we were able to lay out all the parts. Here's what we know we're missing:
1 voice chip
Microcontroller
1 7 pin wiring harness
Pitch/mod wheel assembly
Wooden chassis case
All the knobs
One button
Dad started his work on the transformer and planned to work from board to board just trying to get a sense of what might need to be fixed. He didn't get very far - the transformer is bad. So that's where we stand as of this morning. I'm going to get started on pricing the replacement parts we need, starting with the transformer.
nickle15
Re: Polysix Rebuild
Postby Folderol » Fri Apr 23, 2021 2:02 pm
Best of luck with this.
I suggest you check on availability of the processor and the voice chip before spending too much.
Re: Polysix Rebuild
Postby nickle15 » Fri Apr 23, 2021 2:30 pm
Folderol wrote:Best of luck with this.
Thanks!
Yes I plan to compile a list to see how much it will cost to get the known issues fixed. It's very possible that the cost of the parts would outweigh just buying a functional keyboard.
nickle15
Re: Polysix Rebuild
Postby jjlonbass » Fri Apr 23, 2021 3:04 pm
Which microcontroller is missing? There are 2 - one, a 8049, is the "key assigner" and the other, a 8048, is the "programmer".
Both are mask programmed i.e. the software is hard-wired into the chip - there is no separate PROM. This means that you need the exact correct 8049 or 8048 part containing the correct software. Any old 8049 or 8048 won't work.
I suspect that these will be very difficult to find.
jjlonbass
PreviousNext
