ASM Hydrasynth - what's happened?
Re: ASM Hydrasynth - what's happened?
Postby Eddy Deegan » Wed Jan 20, 2021 12:42 pm
The Elf wrote:All it needs is a third option - on/off/latch-off. Let's call that third option the 'I know what I'm doing' option. How about a big flashing 'LOCAL OFF' on start-up for the hard of understanding?
Sigh... It's this kind of nanny-save-me-from-myself design that has stopped me being able to create feedback loops in Cubase - something I used to find very useful. It is so depressing when we all have to suffer to accommodate ignorance.
I couldn't agree more mate ;)
Some of my works
The SOS Forum Album projects
Postby BJG145 » Wed Jan 20, 2021 12:50 pm
Eddy Deegan wrote:So far, they have refused to implement it on the premise that people turn off local control, forget, and then raise support requests because the synth isn't making any noise. This seems rather a poor excuse to me.
That is the stupidest thing I've ever heard. :headbang:
Elf is right, they have lost it.
Postby The Elf » Wed Jan 20, 2021 1:42 pm
Thanks, guys.
I just hope someone with connections to ASM is reading this and can make someone there see sense. :headbang:
Postby N i g e l » Wed Jan 20, 2021 1:58 pm
what they need is an option for Local Control remembered/forgotten which is set to forgotten by default factory settings.
Postby resistorman » Wed Jan 20, 2021 6:10 pm
What I would like is the ability to change the MPE range from 48.
resistorman
Postby ManFromGlass » Wed Jan 20, 2021 7:21 pm
Elf - you’re creating midi feedback loops in Cubase on purpose? I might have mis-read.
Postby The Elf » Wed Jan 20, 2021 7:38 pm
ManFromGlass wrote:Elf - you’re creating midi feedback loops in Cubase on purpose? I might have mis-read.
Not MIDI, no. I used to create audio feedback loops into which I would embed a delay, filter and distortion plug-ins. This way I could devise custom delays that would repeat and decay in a most appealing manner.
Postby ajay_m » Wed Jan 20, 2021 9:35 pm
The FB page is definitely alive so I wouldn't worry. They're a pretty small corner of Medeli. And probably scrambling to meet demand, this has been a great success in the market. As for the local on thing, Glen said that it was a major cause of returns for Arturia so it was a very deliberate decision. Since my Hydrasynth is hands down the most amazing synth I've ever owned and turned out to match the hype and expectations, I'm gonna say I'm ok with that.
ajay_m
Postby The Elf » Wed Jan 20, 2021 10:35 pm
ajay_m wrote:As for the local on thing, Glen said that it was a major cause of returns for Arturia so it was a very deliberate decision.
And a questionable decision - there are better ways, as we've pointed out above.
You may be OK with it, but when you've got a studio full of synths and one has to be manually 'fixed' every time you power up it becomes wearing. I haven't had a synth default to local-on since my JX-8P in the mid 1980s!
Postby N i g e l » Thu Jan 21, 2021 12:32 am
are ASM at the virtual NAMM ?
Postby CS70 » Thu Jan 21, 2021 12:15 pm
The Third Way! Tony would approve. :D
Postby BobTheDog » Sat Jan 23, 2021 9:07 pm
Mines now disconnected, I’m fed up waiting for them to fix the bugs and their inability to answer emails. Terrible support.
As you say, if you have alternatives why make it difficult for yourself.
BobTheDog
Postby The Elf » Sat Jan 23, 2021 9:53 pm
Well it's the only problem I have with it, and it's fairly minor in the scheme of things. No bugs found here. I'm very happy with it!
Postby Folderol » Sat Jan 23, 2021 10:18 pm
This may be a really really silly question, but can't you just wind the volume down to zero?
Yes. I am that Linux nut.
Postby BJG145 » Sat Jan 23, 2021 11:02 pm
Folderol wrote:This may be a really really silly question, but can't you just wind the volume down to zero?
It's more about ensuring that the controls on the synth have no direct effect on the parameters when it's being controlled by a different keyboard, or a DAW. Their FAQ note that: "MIDI local off...will fix a wide range of DAW/SEQ problems."
PreviousNext
