30-day writing challenge #2: Subharmonicon edition
Re: 30-day writing challenge #2: Subharmonicon edition
Postby Eddy Deegan » Wed Feb 17, 2021 3:39 am
Ben Asaro wrote:I just ran a quick test; yup, the SEQ clocks output whatever divisions you have applied to them from the rhythm generators.
Good to know - thanks for checking that :thumbup:
Some of my works | The SOS Forum Album projects
Postby Ben Asaro » Wed Feb 17, 2021 3:56 am
No problem, it was still on. :)
Ben Asaro
Postby Martin Walker » Wed Feb 17, 2021 7:23 pm
Oooh - real Baba O'Riley territory from about 1-minute in here 8-) :clap:
Postby Martin Walker » Wed Feb 17, 2021 7:29 pm
Ben Asaro wrote:DAY 7. I may be starting to see a 'voice' emerge from the SubH, and much earlier than I was expecting! For this patch, I play each element on its own, and then let the whole thing run. I can definitely image something like this being in stereo with each oscillator panning around.
https://soundcloud.com/user-329043613-5 ... enge-day-7
The anticipation of finally hearing all the elements together is strong with this one.
And at 1:52 I wasn't disappointed - this builds and builds towards 3:10 - glorious!
If you morph this from a writing challenge into a finished track it would indeed sound stunning with separately panning oscillators, but please dial down the reverb ;)
Bravo Ben!
Postby Ben Asaro » Wed Feb 17, 2021 8:06 pm
LOL, noted :)
More than anything I'm seeing a style emerge that's proving to be a lot of fun exploring. I do like the results of Day 7, and if I had recorded enough whole cloth, I probably would have kept it for use later ... alas, the settings are already changed and the odds of recreating it are effectively nil. Such is the nature of modular!
Ben Asaro
Postby John Stafford » Thu Feb 18, 2021 10:40 am
Sounds great! It's nice to hear a deep exploration of the Subharmonicon.
John Stafford
Postby Ben Asaro » Thu Feb 18, 2021 2:21 pm
Thanks, John!
Ben Asaro
Postby Ben Asaro » Fri Feb 19, 2021 4:51 pm
DAY 8. Another fun one! Quite a bit of outboard gear used on this patch. I
Today's experiment involved using an external sequencer (NerdSeq) to send clock and reset triggers to the SubH. I then set VCO1 and VCO2 to different rhythmic divisions. That in itself created some nice counterpoint, but I also wanted a more steady pulse from the SubH. So I took the audio output from VCO Sub2 and ran that though the Dynamix (VCA and filter). I used the SEQ1 clock output to trigger an EG and then mixed the Sub H's VCA output with the Dynamix with a 3rd VCA. Final touch was to add some filter sweep via the SSF Modbox, sync'd to the clock output from the SubH and attenuated via a Doepfer A183-3. Changing the mixer VCA, filter cutoff, and attenuation amounts created a varied soundscape.
https://soundcloud.com/user-329043613-5 ... enge-day-8
Ben Asaro
Postby Eddy Deegan » Sat Feb 20, 2021 7:28 pm
I like this; it would make a very nice foundational groove to develop with other synths in the context of a track. The SH shines when patched with external modules and it'll be interesting to hear where this process of methodical exploration leads you :thumbup:
Postby Ben Asaro » Sat Feb 20, 2021 8:13 pm
Ya know, it's interesting: I follow a couple of musicians on YouTube that make plenty of music using only the Subharmonicon and Mother-32; they're certainly not running out of ideas! However, I think I'm discovering that I'm less drawn to the SubH as a stand alone instrument than I am as an idea box, if you take my meaning. Once I have an idea, I like to see how I can use the SH as a component of a larger patch, not as the be-all, end-all of it.
At least, that's what early indications are in my explorations.
Ben Asaro
Postby Martin Walker » Sun Feb 21, 2021 1:19 am
Ben Asaro wrote:DAY 8. Another fun one! Quite a bit of outboard gear used on this patch.
Wow - that turned out to be most cathartic. I followed it all the way through with interest, but when it stopped I felt a great calming of the force!
It was almost like meditating :shocked:
Postby Ben Asaro » Sun Feb 21, 2021 1:55 am
lol yes, it kind of sneaks up on you! :)
Ben Asaro
Postby Ben Asaro » Sun Feb 21, 2021 2:59 am
DAY 9. Broke out the oscillators again, I'm really liking the sound sculpting opportunities here! VCO1 > Dopfer LPF, SUB1 > Doepfer SEM filter, VCO2 SUB2 > Make Noise Dynamix.
https://soundcloud.com/user-329043613-5 ... enge-day-9
Ben Asaro
Postby Ben Asaro » Wed Feb 24, 2021 4:39 am
DAY 10. The additional ladder filters work a treat! I am now seeing the Subharmonicon as a masterful soundcape creation tool. Having the ability to control the envelope of each voice separately, even if the variance is very slight, really brings the SubH to life -- The only major drawback is that it requires another $1200 in modules. :D
https://soundcloud.com/user-329043613-5 ... nge-day-10
My next experiment will be to see if I can apply a fractional offset or precision adder to the VCOs to transpose the sequences.
Ben Asaro
Postby Ben Asaro » Wed Feb 24, 2021 9:54 pm
DAY 11. Okay, fair warning for this one: it sounds weird, like the sound track to someone's mental breakdown lol.
BUT -- it's a solid proof of concept, at least. Using the Disting, I was able to apply a fractional offset to VCO1 and get it to transpose a 5th up; so the pattern switches keys from CMaj to GMaj.
https://soundcloud.com/user-329043613-5 ... nge-day-11
Now that I know it's possible, time to see if I can get some more musical results from it ...
Ben Asaro
PreviousNext
