Behringer 2600 spring reverb - it's worse than I thought
Page 1 of 2
PostPosted: Thu Feb 25, 2021 9:44 pm
by The Elf
I've been trying out the B 2600 in anger today. It's a very good synth in all but one respect - that dismal digital recreation of a dismal spring reverb.
For me a real spring reverb would be just as unwelcome, but I can report that this one does at least sound like you're playing inside a disused water tank - so there's some level of authenticity here.
HOWEVER... :headbang: :star: :o :madas:
This monstrosity has one very nasty additional surprise in store. It is, in fact, a mono reverb with the L/R channels in opposite polarity. At least it is on this one here. Flip it into mono and... the reverb disappears (almost a blessing, but still...).
Can anyone please confirm or deny that their B 2600 is the same? If they are all like this then there are going to be some red faces when stereo recordings featuring the 'spring' hit mono playback systems. If it's just mine then so be it. I'm as sure as I can be that there is nothing wrong with my connections. But I can't believe I'm the only person to notice this, if they are all the same? :headbang: :ugeek:
For myself it's pretty much a non-issue. I'd already made an insta-bypass around the reverb, even before it was switched on, and it will be returned and remain that way. It's taken from lunchtime until now for me to be even curious about the reverb.
Re: Behringer 2600 spring reverb - it's worse than I thought
PostPosted: Thu Feb 25, 2021 9:53 pm
Am I right in thinking Berhringer have a history of adding mono digital effects to several of their synths?
PostPosted: Thu Feb 25, 2021 9:55 pm
by The Elf
Hugh Robjohns wrote:Am I right in thinking Berhringer have a history of adding mono digital effects to several of their synths?
The Odyssey has a stereo effects processor and only a mono output (it even lets you select a ping/pong preset). I'm not aware of any other anomalies.
The 2600 has stereo outputs, but this time they add a mono effect? :headbang:
I haven't see this polarity trick used since the Korg DW/EX-8000's delay effect from the mid-1980s!
PostPosted: Thu Feb 25, 2021 10:15 pm
by BJG145
I like listening to The Elf complaining about gear. I went to pour myself a shot of Jura when I noticed this thread.
PostPosted: Thu Feb 25, 2021 10:26 pm
by The Elf
Well, TBH this defect (if such it is) will affect me least, so it's no biggie :lol: . For anyone that creates a stereo mix, including the pseudo-spring, that gets played over a mono PA... Oh dear...
Other than this bit of nonsense it's a fabulous synth. I never wanted the reverb anyway, so I'm a happy bunny. :lol:
PostPosted: Thu Feb 25, 2021 10:41 pm
by BJG145
They do look very nice, must admit!
PostPosted: Thu Feb 25, 2021 11:01 pm
by Arpangel
What? spring verbs are so cheap, what’s with digital? Behringer are loosing me (lost me?) by the second.
Still, they haven’t quite made it to the big time yet, Safari and Google spell check still doesn’t auto correct their name.
PostPosted: Thu Feb 25, 2021 11:23 pm
by Agharta
There's something very reassuring about this thread.
SOS forums delivering the goods once more.
PostPosted: Thu Feb 25, 2021 11:36 pm
by The Elf
Some people are telling me the original 2600 was the same, others that it was a stereo spring. I have no idea one way or the other.
If it was the same then that's:
a) Fair enough :thumbup:
b) Just as daft :lol: :headbang:
PostPosted: Thu Feb 25, 2021 11:45 pm
by nathanscribe
I was thinking of starting a 50p charity jar every time Elf complains about spring reverbs, but I don't earn enough.
That polarity issue is a shocker though.
PostPosted: Fri Feb 26, 2021 12:23 am
by N i g e l
A really intriguing thread, well done Elf :thumbup:
I googled ARP 2600 service manual & the one that came up
http://dl.lojinx.com/analoghell/Arp2600 ... Manual.pdf
has the reverb module circuit on page 28 of 53.
the mono output of the reverb unit goes to 2 separate opamp circuits on the way to the main outputs. Those opamp +/- inputs are used differently on the L& R path i.e. one is inverted .
PostPosted: Fri Feb 26, 2021 12:32 am
by The Elf
N i g e l wrote:the mono output of the reverb unit goes to 2 separate opamp circuits on the way to the main outputs. Those opamp +/- inputs are used differently on the L& R path i.e. one is inverted.
Well done, mate. :clap:
Well, no-one can complain that it doesn't try to be authentic then!
I predict a spate of Internet postings about disappearing reverb! :mrgreen:
PostPosted: Fri Feb 26, 2021 1:48 am
by Martin Walker
The Elf wrote:I predict a spate of Internet postings about disappearing reverb! :mrgreen:
It's probably just a phase they're going through ;)
PostPosted: Fri Feb 26, 2021 4:33 am
by shufflebeat
You're cancelled!
PostPosted: Fri Feb 26, 2021 8:58 am
by Luke W
:lol:
