Yesterday when turning on my JD990 it showed a blank screen with black horizontal stripes. After several on / off operations, it still started working, but then it stopped working again. Sometimes, instead of black stripes, the inscription "Super JD" first appears, but then the stripes appear again. These stripes can move from top to bottom, and a subtle "Super JD" may appear in the background. There is a suspicion that there was a power surge yesterday, and the JD 990 could fail ...
small addition: the module began to turn on, and the main menu appeared (patch selection), but gradually (within 2-3 seconds) the inscriptions disappear and stripes appear again. As a result, the "Internal All - Factory Reset" menu appeared, I pressed Execute, after which the module seemed to be working normally. Maybe the reason for all this is the increased voltage in the network?
