Having cleared out a few bits of unused gear I have taken my first steps into a larger world. (As Obi Wan would say).
I've ordered a rack case with power, a Behringer Neutron and a Behringer 914 filter bank. That's my starter kit.
Unusually (it would seem) I intend to use the modular for musical purposes rather than random atonal bleeps that seem to be the mainstay of modular racks if YouTube is anything to go by.
I am also building my own modules.
Who else uses their modular as a giant synth rather than a beep-booper?
Venturing into Eurorack modular
• Page 1 of 2 • 1, 2
Re: Venturing into Eurorack modular
Alanqa wrote:Unusually (it would seem) I intend to use the modular for musical purposes rather than random atonal bleeps
Subscribed. Let's see what happens...
desmond - Jedi Poster
Alanqa wrote:Who else uses their modular as a giant synth rather than a beep-booper?
A tiny percentage, basically no one.
BobTheDog - Frequent Poster
On the contrary. I use mine as a flexible melodic instrument mostly, but it's also handy for a bit of utility work (trigger processing etc) and a few odd effects. That's the beauty of modular, you build what you want.
nathanscribe - Frequent Poster
I enjoy messing about with mine just for the fun of it but my main objective for it going forwards is to create textures & breaks that I can incorporate into bigger works.
I've also found it to be a muse of sorts as it can be surprisingly inspirational when composing.
Eddy Deegan - Moderator
I use mine as an ambient soundscape generator, which at least has longer form bleeps and bloops. I use Arbhar as the sound generator into various echo, looping, filter, resonance, and reverb modules. Also sounds great with my guitar!
resistorman - Frequent Poster
I'm not quite at the Eurorack stage, but I do have some kit arriving in a month or so. But... it will be a basic synth for leads, basses and playing from a keyboard - not bloops!
The Elf - Jedi Poster
Ben Asaro has been posting lots of interesting, and tuneful, stuff on his deep dives recently.
blinddrew - Jedi Poster
Hey, thanks!blinddrew wrote:Ben Asaro has been posting lots of interesting, and tuneful, stuff on his deep dives recently.
Yessss, bleeps AND bloops! Perhaps the biggest reason for this is because polyphony in eurorack is eye-wateringly expensive and you can get an analogue synth voice for a fraction of the cost of eurorack... at least in my experience.
It took me 3 years before I found my stride with eurorack. I’m a huge fan of experimental music but I’m too much of a melody junkie to do it myself. I’ve learned that my modular jam is Berlin school soundscapes.
This is the result of my eurorack deep dive,
https://donmusicpresents.bandcamp.com/album/golden-disc
- Ben Asaro
- Frequent Poster
I think Colin Benders and Kaitlyn Aurelia Smith do bleeps and bloops in a very pleasant way.BobTheDog wrote:Alanqa wrote:Who else uses their modular as a giant synth rather than a beep-booper?
- Ben Asaro
- Frequent Poster
Ben Asaro wrote:I think Colin Benders and Kaitlyn Aurelia Smith do bleeps and bloops in a very pleasant way.BobTheDog wrote:Alanqa wrote:Who else uses their modular as a giant synth rather than a beep-booper?
+1 to both of those suggestions!
State Azure is also worth a look/listen. Almost exclusively modular orientated; specialises in long generative pieces but does a fair amount of live and semi-live material as well.
I like that. There's something quite organic in there that's appealing to my ears.Ben Asaro wrote:This is the result of my eurorack deep dive,
Ben Asaro is a great example of someone who can show you many uses of a modular system.
My opinion is that there is no defined use of a modular, it can be what you want it to be, that’s the whole point of them, as opposed to an off-the-shelf system.
YouTube? Just don’t go there, it’s not a true representation of anything, it’s just a confusing malaise of self serving individuals most of the time, there are a handful of good guys giving useful information, but not many.
I designed my modular as a random source, and effects unit, I could have made it more "versatile" but there is a danger with modular, you have to decide what it is specifically that you want to achieve, and make a no-compromise system for that purpose, otherwise, you can find that your box isn’t particularly good at any one thing, if you try and make it "too versatile"
PS, this "bleeps and hoops" random thing, there is more to this than meets the eye, birdsong, the sounds of nature, weather, are all truly random, and in these technological times, a lot of people are disconnected from nature, and they crave it, randomness, sine thing that seems to have a life of its own, can be a sort of substitute, it’s not to be underestimated.
Arpangel - Jedi Poster
Thanks, Elf! Your guidance and advice has had no small impact in the way I approach my arrangements!The Elf wrote:I like that. There's something quite organic in there that's appealing to my ears.Ben Asaro wrote:This is the result of my eurorack deep dive,
- Ben Asaro
- Frequent Poster
There is a glut of similar information on YT, but I think if you avoid the 'content' (i.e., larger) channels, there's shed loads of interesting music and informative stuff on YT.Arpangel wrote:YouTube? Just don’t go there, it’s not a true representation of anything, it’s just a confusing malaise of self serving individuals most of the time, there are a handful of good guys giving useful information, but not many.
If you have the budget, space, and time to 'go big', I say, go for it -- but you are quite right: generally speaking, you will only use small bits of a system at one time. I find myself using only a couple of voices, for example, but every dang utility I have available time and time again. Depends on what you're going for and how much patience you have to tune the thing, also.have to decide what it is specifically that you want to achieve, and make a no-compromise system for that purpose, otherwise, you can find that your box isn’t particularly good at any one thing, if you try and make it "too versatile"
- Ben Asaro
- Frequent Poster
