[Synthesis] Please help with re-making this sound
Postby methodonez » Sun Apr 25, 2021 9:06 pm
hi y'all. I'm at the very beginning of trying to teach myself synthesis by deconstructing and recreating fairly simple sounds and have been trying at this bassline for a good few hours now, but I can't seem to get anything satisfactory.
could anyone please point me in the right direction? what am I missing?
this is the bassline that I'm trying to recreate:
https://voca.ro/14f3fKYfSt2R
this is what I have:
https://voca.ro/1hGHNe1q6FLV
any help would be greatly appreciated <3
-m
methodonez
Re: [Synthesis] Please help with re-making this sound
Postby Eddy Deegan » Sun Apr 25, 2021 10:09 pm
Welcome to the forum :wave:
Although the timbre isn't quite the same it's close enough to get the effect. The main thing I noticed is that your amplitude envelope needs a bit of adjusting :-)
Set the sustain and decay (correction: I meant 'release' instead of 'decay' here) stages of the envelope to zero, set a fast attack and a reasonably fast decay. What will happen is that the note will not sustain even if you hold the key down, and the decay stage will determine the length of the note. Experiment with the decay until the length of the note feels right.
Postby Dave B » Mon Apr 26, 2021 12:41 pm
Eddie is right - fast attack and decay. AND some release as well.
It sounds like 2 (maybe 3) oscillators which are saw wave and the other(s) ever so slightly detuned against the main oscillator. The filter is quite, so start with higher values and take down slowly until it matches.
Dave B
Postby Wonks » Mon Apr 26, 2021 1:36 pm
Eddy Deegan wrote:Set the sustain and decay stages of the envelope to zero, set a fast attack and a reasonably fast decay.
Should one of those decays be 'release' as the decay can't be both zero and reasonably fast. But as the sustain is zero, then there is no release to speak of, so maybe one too many decays?
Just want to clarify it for the OPs sake.
Postby Eddy Deegan » Mon Apr 26, 2021 2:01 pm
Oops, my bad... I said 'decay' instead of 'release' - well spotted Wonks!
Fast attack, fast-ish decay, zero sustain, zero release. Alter the decay until the note sounds punchy/bouncy enough.
Postby Wonks » Mon Apr 26, 2021 9:44 pm
Thanks, Eddy.
