Moog Grandmother, mod-wheel/Eurorack issues.
Postby Arpangel » Mon Apr 26, 2021 6:35 am
I’ve tried, but can’t find a way to output mod-wheel CV from my Grandmother to my Eurorack, to control a VCA/LFO for vibrato.
You can access the the raw LFO wave on the grandmother, but it’s not tapped via the wheel.
I need to tap off the mod wheel to control a VCA on my modular, but it’s not happening, I’ve looked on other synth forums, and others have had the same issue, looks like it’s not possible.
This is a great shame, as it stops the GM being a really nice all-in-one controller, just running this by you folks, to see if you have any answers.
Re: Moog Grandmother, mod-wheel/Eurorack issues.
Postby BJG145 » Mon Apr 26, 2021 8:37 am
Could you get round it with a MIDI module, or by running it through another synth as described here...?
https://forum.moogmusic.com/viewtopic.php?t=31497
Postby Arpangel » Mon Apr 26, 2021 8:48 am
BJG145 wrote:Could you get round it with a MIDI module, or by running it through another synth as described here...?
Thanks, yes, that’s the conclusion I came to, I could plug it into my Micron, but that only has Midi out, so I’ll have to get a Doepfer 192-3 or similar.
Are they saying a Korg MS20 "can" output mod wheel info via CV?
This is all a bit strange, I’m jot focusing, the reason I want to use the GM is to use its sequencer and arpeggiator, nit the sounds, basically an Arturia Keystep would do the job better.
Postby BJG145 » Mon Apr 26, 2021 8:53 am
Arpangel wrote:Are they saying a Korg MS20 "can" output mod wheel info via CV?
That's what they're saying.
Here's the output on the Mini.
https://youtu.be/wdxzgN2t26E?t=23
Seems to look the same on the original.
Postby Arpangel » Mon Apr 26, 2021 8:57 am
Interesting, but doesn’t the Korg use different CV voltages, I’ll need another converter?
Postby BJG145 » Mon Apr 26, 2021 9:05 am
...hmm, looks like you might. The English Tear seems a popular choice...
https://postmodular.co.uk/modules/english-tear/
...but perhaps there's a simpler/cheaper option.
Postby Arpangel » Mon Apr 26, 2021 9:15 am
BJG145 wrote:...hmm, looks like you might. The English Tear seems a popular choice...
Using the MS20, and the GM, I’m sort of missing the point, after thinking about this more, the simplest solution would be a Doepfer A192-3 Midi/CV converter, or, a KeyStep if I wipe out the GM, I’m not using the sounds in the GM alongside the modular, so a KeyStep would actually do a better job, it has more comprehensive sequencing and arpeggiation.
The GM is just there, it wasn’t an ideal solution, but not having a mod CV out is a bit of an annoying omission, it would have been a perfect modular controller for me, if it had one.
