Aria Sinsonido preamp repair
Re: Aria Sinsonido preamp repair
Postby Dr R » Tue Jun 05, 2018 1:35 pm
James Perrett wrote:Is it a dual ganged pot and, if so, have you checked the other half (pins 2, 4 and 6?
Are you suggesting that the odd pins form one potentiometer, and the even pins form another, independent but on the same shaft? I hadn't thought of that (probably because of the afore-mentioned 30 year gap). In which case what combinations should I test?
Dr R
My ambition: To one day have enough experience to answer technical questions on the SOS forums, as well as asking them
Postby Hugh Robjohns » Tue Jun 05, 2018 3:36 pm
That would be the usual arrangement, with 2 and 4 being the wipers.
Postby Wonks » Tue Jun 05, 2018 4:02 pm
Hugh Robjohns wrote:That would be the usual arrangement, with 2 and 4 being the wipers.
In keeping with DR R's numbering system, that would be 3 and 4 surely?
Postby Wonks » Tue Jun 05, 2018 4:16 pm
The volume pot is marked A1k, so should be a 1k ohm dual-gang pot with an Audio/log taper (as one would expect for the volume pot), and the tone is marked B1k so should be a 1k ohm dual-gang pot with a linear taper.
So with one of the dual gang pots being pins 1, 3 and 5, and the other being pins 2, 4 and 6 you should get a constant around 1k ohm between pins 1 & 5, and pins 2 & 6. Between pin 1 and pin 3, or pins 3 and 5, you should get a variable resistance that varies either from (near) nothing to 1k, or from 1k to nothing. Likewise with pins 2, & 4 and 4 & 6.
On the tone pot, the resistance from either of the outer pins to the central wiper in the mid-position should be around 500 ohms. On the volume pot, because of the different taper, it should be around 200-300 ohms from one end pin to the wiper, and between 700- 800 ohms from the wiper to the other end pin.
The above ignores any effect of other components being wired across the pots in parallel, which may affect the resistance readings somewhat (difficult to say without a circuit diagram) which could lower the resistance readings, but you should still always see a variation of resistance between the central wiper pin and the two end pins.
Postby Dr R » Tue Jun 05, 2018 4:23 pm
So to get the full picture I need to check all the resistances
R15, R13, R32, R26, R24, R46 on each pot. (Rnm being the resistance between the pins n&m)
R12 will presumably be nothing to do with the pot, and measuring the resistance of other components on the board.
It looks from the picture that 5&6 are linked on one pot at the back of the board. That would make them ground. So (brain slowly getting there), would that make pins 1 and 2 the Vin for each pickup and 3,4 being the output?
Many thanks for everyone's interest in the problem, and patience!
Dr R
Postby Hugh Robjohns » Tue Jun 05, 2018 4:28 pm
Sorry -- yes, well spotted. Typo on my part!
Numbering the pins according to the photograph above as
2, 4, 6
1, 3, 5
with 1, 3, 5 closest to the shaft.
So 3 and 4 are the wipers...
Postby Wonks » Tue Jun 05, 2018 4:42 pm
Dr R wrote:It looks from the picture that 5&6 are linked on one pot at the back of the board. That would make them ground. So (brain slowly getting there), would that make pins 1 and 2 the Vin for each pickup and 3,4 being the output?
That would be the most likely arrangement, though it is possible that the inputs are via the wipers (3 and 4) and the outputs on 1 and 2.
As the tone control seems to be a simple treble-roll off type, then it could be a passive tone type similar to an electric guitar, where the pot isn't used as a potential divider with all three pins connected, but as a variable resistor, with just two of the pins connected, one being the wiper. The pot controls the amount of high frequency passed down to ground via a capacitor wired in series with it. It may well be an active circuit, but don't be surprised if pins 1 and 2, or 5 and 6 aren't connected to anything else.
Postby Dr R » Tue Jun 05, 2018 6:56 pm
Thanks all. That's tomorrow lunchtime sorted
Dr R
Postby ef37a » Tue Jun 05, 2018 7:02 pm
My brain hurts.
There are surely tracks under those pots that you cannot see. I think you need to test for S/C links and draw a "net" of the pot wiring.
Are you sure there isn't an SM capacitor rolling around somewhere?
Postby Dr R » Tue Jun 05, 2018 8:08 pm
ef37a wrote:My brain hurts.
There definitely are no components knocking about loose, though anything surface mount could have escaped while the guitar was away; there are no gaps on the board I can see where something might have fallen off.
However there are tracks under the tone pot, running from the two .47 capacitors next to it
I am sorely tempted to take Folderol up on his kind offer and post the board to him, but that feels like giving up early!
Dr R
Postby James Perrett » Tue Jun 05, 2018 10:07 pm
One thought - does this bass have a stereo output (like Rickenbacker's used to)? I'm trying to work out why they would go to the expense of dual ganged pots. Could it be that one half of the circuit is connected to one pickup while the other half is connected to the other pickup? If so, does the tone control not work on both pickups?
Postby Hugh Robjohns » Tue Jun 05, 2018 10:19 pm
Yes, I wondered that too. It does appear to have a three-core output lead from the circuit board to the output socket.
Postby Dr R » Wed Jun 06, 2018 5:40 am
It is described as having stereo microphones on the web site. The output voltage at the socket is very high compared to my active bass, as well, so it may possibly drive headphones.
I'll ask, and do some more experiments.
Rich
Dr R
Postby ef37a » Wed Jun 06, 2018 5:56 am
Ah! "Headphones" that makes sense of the use of the LM386s.
And stereo, could be some weird phase anomaly going on?
Postby Hugh Robjohns » Wed Jun 06, 2018 8:30 am
Reading around, it does appear that it is intended to drive stereo headphones directly, but can also be used like a conventional electric bass to feed an amp.
Postby Dr R » Wed Jun 06, 2018 12:26 pm
Hi All,
Hugh is correct, the bass does indeed drive headphones directly - and really very loudly as well!
The two pickups are wired in stereo, left and right. There is no discernible stereo effect on headphones, it's not as if one pickup is closer to the E and one to the G and there is a spread across the image. However shorting one pickup clearly removes the signal from one channel. (I'll post a photograph of the very Heath-Robinson "test environment" later on :D )
Testing the pots more comprehensively:
A - Volume
  • R15= 1.004K
  • R13= 1.004k/5.9ohm
  • R35= 5.9ohm/1.004K
  • R26=0.950K
  • R24=0.950K/5.5ohm
  • R46=5.5ohm/0.950K
all makes sense, operating as pair of potentiometers with 3, 4 as the wipers.
B- Tone
  • R15=5.6ohm/1.056K
  • R13=3.3ohm
  • R35=5.5ohm/1.053K
  • R26=5.6/1.056K
  • R24=3.3ohm
  • R46=5.5/1.052K
makes sense with 1+3 / 2+4 connected together, and then operating just as a variable resistor to change the tone.
So perhaps it's not the pot that is knackered after all? What's next to look at?
As ever - huge thanks to everyone.
Rich
Dr R
Postby Dr R » Thu Jun 07, 2018 6:18 am
Photograph of "Test rig" to confirm stereo wiring from pickups to output:
Maintaining a steady two-finger plucking technique while shorting one pickup with the needle-nosed pliers was hard ;)
The pickups in the Aria are, I think, in the tube that forms the bridge.
As you can see, it's a lot lighter than a typical bass.
Dr R
Postby Folderol » Wed Jun 13, 2018 9:36 pm
ef37a wrote:Ah! "Headphones" that makes sense of the use of the LM386s.
Ding!
Just because you know what I'm talking about, it doesn't mean I do!
Postby Dr R » Thu Jun 14, 2018 8:07 am
Thanks Folderol - I take it that's a lightbulb moment?
I'm don't understand how a phase anomaly would prevent the tone control from affecting the sound, though I can see how it might remove some of the bass frequency, which is also part of the problem.
More confused than ever :?
Rich
Dr R
Postby ef37a » Thu Jun 14, 2018 10:49 am
Dr R wrote:Thanks Folderol - I take it that's a lightbulb moment?
Rich
It is often the case Rich that even quite simple electronic systems display faults that seem to make no sense and a purely logical examination of the circuit (which we have not got!) throws very little light.
Once the fault has been found however it becomes blindingly obvious that "THAT" was why it went T's U! (I call it the "Rumsfeld effect")
PreviousNext
