PAT testing - Is it legally required
Re: PAT testing - Is it legally required
Postby Guest » Mon Apr 01, 2019 9:27 pm
Don't seem to see anyone on this web site advertising The fact that there gear is pat tested and insured
https://www.lastminutemusicians.com/sea ... lists.html
But would you expect this at the base line level for 100-150 quid for crap pub jobs?
Guest
Postby blinddrew » Mon Apr 01, 2019 9:37 pm
Short answer: yes.
Slightly longer answer: yes, because the risks of not having appropriate 3rd party liability cover (or having it declared void because your kit wasn't tested) is simply far too great.
Postby Hugh Robjohns » Mon Apr 01, 2019 10:29 pm
music master wrote:Don't seem to see anyone on this web site advertising The fact that there gear is pat tested and insured
They don't specifically say they can drive themselves to a gig or know how to set their equipment up properly either... But we assume they can and will! ;-)
Yes, absolutely! I appreciate it's all additional overhead costs which you'd rather avoid, but it's one of those things -- like PLI -- that just has to be done because the potential risks of not being able to show that you took reasonable steps to ensure your gear was safe is far too serious and drastically damaging to contemplate.
And it's also seen by many as a mark of serious professionalism and commitment.
If you're lugging your gear around to gigs regularly its going to suffer wear and tear, so it's essential that it is safety checked on a regular basis. The PAT scheme isn't mandatory, but it is a very good way of checking everything important is safe and documenting the fact. Think of it as an MOT for your electrical gear. Having evidence of regular PAT testing will also keep venues and insurers happy, and the sensible venues will insist on it anyway before they let you in the door. Moreover, it could save your bacon should something bad happen outside your control!
So I would encourage you to get your gear PAT tested regularly. I do mine every 6 months for the most heavily used portable gear, annually for everything else.
Also, before you plug anything in at your crap pub jobs, use a mains socket tester first to make sure it's safe -- it's amazing how many duff ones are around -- and ALWAYS use an RCCB (earth leakage breaker).
Postby DavidJGreaves » Sat Apr 27, 2019 9:14 am
One issue is whether to use an automated PAT testing machine or a manual insulation tester. The automated machines are quite expensive and ultimately not as generally useful as an insulation tester with 500 and 1000 volt ranges. Whenever I am making a repair on mains powered equipment I make a manual insulation test. I make the earth continuity resistance tests with a multimeter that works to a tenth of an ohm.
Another issues is the calibration of PAT equipment. Sending it off to an approved lab is expensive whereas just testing it yourself on a few resistors is free. The tolerance required for safe calibration is not an issue, since a 2 to 1 error is not going to affect whether something is safe on not in any real-world situation.
I do not have to regularly test lots of equipment. So when my automated PAT tester failed I did not bother to replace it and I just use my insulation tester, multimeter and various mains cables and probes.
Don't be tempted to make insulation tests with a standard multimeter however. I have an old piece of twin-and-earth cable that makes a good demo: No resistance between live and earth is detected with a standard DMM but the insulation tester on the 500 volt range shows a clear fault. The same piece of cable, when wired to the mains, trips the RCD.
Remember to take great care when using an insulation tester. Mine beeps all the time the voltage is on to keep the user alert.
DJG
DavidJGreaves
Postby AudioPhilisopher » Fri Feb 14, 2020 5:02 pm
I've always gotton a pass with my pat testing. It's a bit of an annoying tax you pay just for some beauracracy.
PAT testing was designed for stuff in offices, where you have no tech looking over things, kettles, photocopier etc. which may have electrical faults and the staff are none the wiser.
When studio equipment develops electrical faults, we know it immediately because there's tell tell signs from the audio & interference being output.
It isn't legally required but most insurances will require it to cover their backs. You may find that some insurance will actually require the equipment to be PAT.
it's fairly cheap to do if you don't bring in new equipment every couple of months. You can do just 1 annual inspection and for around £80 you can get 100 items tested. If you're bringing in new equipment, that means a new callout, and a flat fee starting from £80 to do the tests- it will add up.
Aside from the cost, it's the inconvenience of getting everything out, all the cables etc and having it prepared for the PAT tester to do their stuff.
A mate of mine doe PA hire, he ended up doing a PAT course, and self certifing his own equipment. It cost £300 to do the course and the device he got was £300 but he can issue his own PAT labels for the equipment.
AudioPhilisopher
Postby AudioPhilisopher » Fri Feb 14, 2020 5:04 pm
geefunk wrote:I neeed some advice on this too. I'm in a school, and we've just had an annual PAT test, and 8 of my brand new, still in the box power extension reels were failed because they have 10amp cable (13amp plug/fuse), and it is thinner than 13amp cable, so illegal?
We already had one in the school, and it was passed by the company last year, but a different company have failed it this year. What is the situation?
Use a 10 amp fuse?
AudioPhilisopher
Postby Sam Spoons » Fri Feb 14, 2020 6:42 pm
As I understand it you don't need to do a course* to be able to PAT test (ok I know but PA testing means something completely different on here) electrical equipment. The only requirement is that the test is conducted by a 'competent person'. The other crucial thing is to keep records. I do my own but would probably not get involved in doing anybody else gear. If you are not up to speed the prudent thing is to get an electrician to do the job for you.
* Obviously this may change in the future and, if you don't know how to conduct the tests then a course is a very sensible way to learn how.
Postby OTE2020 » Sun Mar 29, 2020 7:04 pm
''As I understand it you don't need to do a course* to be able to PAT test ''
This is what i was told a few years ago as well, you just ''an idea'' on what your doing... .... ....
OTE2020
Postby Hugh Robjohns » Sun Mar 29, 2020 7:08 pm
You don't have to do a course if you can demostrate you already have sufficient knowledge, technical understanding, and experience to be deemed 'competent' in a court of law... Should you judge something safe that wasn't and someone sues over it!
Postby Adam H » Mon Mar 30, 2020 3:26 pm
I taught music tech in a 6th Form college for 15 years and, like many, the college put me through the PAT course as it was cheaper.
It was a one day course and the guy who taught it was very good, and also quite pragmatic about the whole PAT phenomenon. One of the points he raised, addressing the point by Hugh above, is 'what about if someone tries to sue me, if they are injured by something I passed'.
Turns out it would be quite difficult, unless it could be shown that the equipment was _unsafe when you passed it_. The PAT is like an MOT - passing it says the equipment was safe at the time of inspection. If, a week down the line it's been dragged around a warehouse by the plug a few times, it then shocks someone, that's hardly the tester's fault.
In a commercial situation, where h&s is everyone's responsibility, there is an onus on all users of electrical equipment to ensure it's safe before using it, and the green sticker on the back is no excuse!
Adam H
Postby Hugh Robjohns » Mon Mar 30, 2020 5:14 pm
Adam H wrote:Turns out it would be quite difficult, unless it could be shown that the equipment was _unsafe when you passed it_. The PAT is like an MOT - passing it says the equipment was safe at the time of inspection. If, a week down the line it's been dragged around a warehouse by the plug a few times, it then shocks someone, that's hardly the tester's fault.
True enough... but just saying "It was alright when I tested it, Guv" won't cut it.
So it's not just down to 'them' showing the equipment was unsafe when you passed it; you also have to be able to show 'them' that you are competen to have passed it too.
So if the turds hit the turbocharger you'll need to be able to demonstrate that you tested the equipment it at appropriate intervals -- which means having suitable records -- and that that you were fully competent to test it in the first place.
If you've been on an approved course and received a certificate of competence at then end then that's fine. If you didn't and can't, that's not necessarily a problem, but it's going to be harder work to convince a judge that you really were a fit person to attach the green labels.
And if you aren't deemed a fit person to perform the testing, no one will care who dragged the thing around by its mains lead, the poo will adhere to you.
As you say, PAT testing is not really that difficult and there are loads of approved courses to gain the qualification at reasonable prices.
Postby ruffrecords » Fri Aug 07, 2020 1:01 pm
If a band comes into your studio with its own guitar amps etc, do you insist it is all PAT tested? Your risk assessment would probably highlight gear from an unknown source as a risk.
Cheers
Ian
ruffrecords
