D.I.Y. MIDI/5-pin DIN to stereo mini Jack leads
Postby db73 » Mon Oct 31, 2011 4:29 pm
I want to make my own MIDI to jack leeds for use with an IK iRig MIDI interface. I'm a bit unsure about how the cables are soldered to the connectors. I've found a page that shows how to solder the cables to the MIDI connector (only 3 of the 5 pins are used). But I'm not sure about the stereo jack end. Does anyone know? This is what I am trying to make;
http://www.kenable.co.uk/product_info.php?products_id=4723
Cheers ;)
db73
Re: D.I.Y. MIDI/5-pin DIN to stereo mini Jack leads
Postby James Perrett » Mon Oct 31, 2011 5:44 pm
IK seem to be using custom cables which need to be specially made. I've never seen anyone else use jack connectors for MIDI. IK don't seem to have any info on their website so it might be worth contacting them to find out the pin assignments on their connectors. There is also a guy from IK (Brian?) who posts advertising blurb here from time to time so maybe he'll pop up and post something helpful.
The cable you linked to was for audio, not MIDI, and certainly won't work as MIDI uses a different pin combination to audio.
James.
Postby db73 » Mon Oct 31, 2011 7:30 pm
Thanks for the reply, James. I did email IK but they just replied back saying that they would be selling these at some point soon! They didn't respond to the bit I put in about connector soldering connections to make my own cables. I might email back requesting the information again.
In the mean time I've ordered a male to male MIDI cable (which I'm going to splice in half) and a couple of 2.5mm stereo connectors. I'm half tempted to butcher one of the supplied MIDI to stereo 2.5mm mini jack connectors to see how they are connected :tongue:
db73
Postby zenguitar » Mon Oct 31, 2011 10:41 pm
db73 wrote:I'm half tempted to butcher one of the supplied MIDI to stereo 2.5mm mini jack connectors to see how they are connected :tongue:
Resist the temptation, use a multimeter or similar to identify which MIDI pins the tip, ring, and sleeve of the minijack are connected to.
Yogi Berra
Postby ef37a » Tue Nov 01, 2011 8:50 am
Since MIDI uses pin 2 as shield and pins 4&5 for data (the shield is not a "return" as for audio and is not in fact needed for data transfer) it is hard to imagine the 2.5mm jack being wired to anything other than sleeve shield, tip and ring data?
James is correct, that jack in the link will be wired to pins 1&3 if it is a mono in and out but alternatively 1&4 or 5&3 if just a stereo in or out cable, none of which will work for MIDI.
However if you are being ripped a bit for the "proper" leads you could chop the DIN off and wire one to the right configuration.
Personally however I would make up a DIN inline socket to plug lead and work out the "translation" of the wires. Then you can convert any and all you find.
Postby db73 » Tue Nov 01, 2011 12:32 pm
Cheers guys. Great idea about using a multimeter. I borrowed one in work this morning & worked this out.
This is how the cable is wired up (if anyone is interested);
db73
Postby ef37a » Tue Nov 01, 2011 1:30 pm
Told ya!
BORROWED a meter? C'mon, don't be cheap...http://www.maplin.co.uk/manual-ranging- ... test-44679.
Postby db73 » Tue Nov 01, 2011 2:37 pm
ef37a wrote:Told ya!
You're right. I should buy one really. Handy to have for cable testing & I keep wanting to get into electronics at a basic level ....... working my way up to build my own analogue mono-synth, which I will use to take over the World. MMUUHUUHAAAAA!!! :bouncy:
db73
Postby Martin Walker » Tue Nov 01, 2011 2:46 pm
Good luck in taking over the world - I'm sure it will be a nicer place than it is now under your leadership 8-)
Postby ef37a » Tue Nov 01, 2011 2:46 pm
Ha! For cable checking best get a meter with an audible bleep, so much quicker I find. Or build your own bleeping continuity tester!
Postby Folderol » Tue Nov 01, 2011 9:26 pm
Well, OK, but there's no need to swear :roll:
Postby db73 » Thu Nov 03, 2011 12:15 am
Got the 2.5mm jack plugs in the post today. Erm, not what I expected to see inside! Where are the soldering points for the tip & ring?! Is that them in the middle of that black plastic part? Guess I'll have to get the multi-meter on this as well.
db73
Postby db73 » Thu Nov 03, 2011 9:06 am
..... I'm assuming it's like this (not got the multimeter on this yet);
db73
Postby zenguitar » Thu Nov 03, 2011 1:32 pm
Use the meter, but my guess is that you have the ground to the sleeve correct and the tip and ring reversed.
Yogi Berra
Postby Folderol » Sat Nov 05, 2011 10:00 pm
zenguitar wrote:Use the meter, but my guess is that you have the ground to the sleeve correct and the tip and ring reversed.
Bang on the money.
Unfortunately that plug looks like those evil nickel plated ones that are a nightmare to solder :frown:
You absolutely must put it in a tight fitting socket of some sort before attempting to solder it or the plastic will deform and the thing will become useless!
If it is that hard shiny nickel plating I also recommend filing down to the underlying brass with a needle file.
