Digital amplifier repair (Flying Mole) - help needed
Postby Dan B » Tue Dec 06, 2011 7:08 pm
Hi
I have 2 x Flying Mole DAD M100 Pro HT class D monoblock amps which I am using to power my PMC TB2+ speakers. One of the amps has now developed a fault: it distorts quite severely, with more distortion the higher the input level. I have tested all the other items in the setup and it is definitely the amp that is the problem. It appears Flying Mole are no longer in business and not responding to email, and - despite lots of effort - I'm struggling to find anyone who will take a look at it. These amps don't seem to be available any more, so replacing it doesn't seem to be an option. Meaning repair, or replacing both monoblocks with something else(which I can't really afford - especially given how good the Flying Moles were for the money).
Can you recommend someone who might be able to help? I gather there's further complication: the components on the FM amps do not appear to be labelled, so even if I am able to identify the faulty components it may be hard to know what to replace them with....!
I am based in London.
Many thanks,
Dan
Dan B
Re: Digital amplifier repair (Flying Mole) - help needed
Postby Kwackman » Tue Dec 06, 2011 7:20 pm
You could try PMC to see if they know of anyone.
http://www.pmc-speakers.com/
Kwackman
Postby Hugh Robjohns » Tue Dec 06, 2011 7:22 pm
Dan B wrote:One of the amps has now developed a fault: it distorts quite severely, with more distortion the higher the input level.
How odd! I've just been helping a friend trouble shoot his four year old TB2As, one of which was distorting in a similar way to yours, and identified the Flying Mole amp as the cause. Discussing it with PMC today I was told that they don't have any serviceable replacements and can't offer a repair, so my friend has decided to upgrade to the DS001 amps (which are twice as powerful) instead.
The best advice I can offer is to get in touch with Ian Downs at PMC (ian at promonitor dot co dot uk) and see if he has a working trade-in Flyng Mole you could purchase, or maybe offer you an upgrade to PMC's own DS001s.
Hugh
Postby Dan B » Tue Dec 06, 2011 7:31 pm
Thanks.
I actually emailed PMC earlier today, so I'll see what they say. I'm afraid I can't afford to move up to the DS-001, much as I'd like too.
At a stretch, I could afford to replace one of the Moles with an identical one - but there don't seem to be many of them around for sale (new or s/h).
My only other option at the moment is to dust off my old Samson Servo 260 (argh) or - slightly better - an ageing Panasonic A400 (with grounding issues). I've been somewhat spoiled by the Moles (which I love - picked up new on an amazing deal - year end close out) and I fear there's little to be had for the price I paid that would hold a candle to them...
Dan B
Postby Dan B » Tue Dec 06, 2011 7:32 pm
P.S. Hugh - might your friend have a spare Flying Mole then, since he's replacing his? Or did both go?
Dan B
Postby Hugh Robjohns » Wed Dec 07, 2011 1:18 am
He returned them to PMC as part of the upgrade deal.
hugh
Postby James Perrett » Wed Dec 07, 2011 12:33 pm
Since the forum title includes DIY, one thing I would think about would be to replace the amplifier module with one of the Hypex UCD modules. Of course, this depends on whether it is possible to separate the power supply from the amplifier and on the power supply having a suitable voltage but it may not be out of the question to also replace the power supply with a Hypex supply.
James.
Postby forumuser695516 » Wed Dec 07, 2011 6:38 pm
James Perrett wrote:Since the forum title includes DIY, one thing I would think about would be to replace the amplifier module with one of the Hypex UCD modules. Of course, this depends on whether it is possible to separate the power supply from the amplifier and on the power supply having a suitable voltage but it may not be out of the question to also replace the power supply with a Hypex supply.
James.
I think it may have been Hugh that hinted that the latest PMC amp modules may contain Class D Hypex gubbins anyway. And even if they don't.. Hypex are still great amps. Albeit in module form (meaning you build the rest of it yourself, but its very easy).
You can make a stereo 200 watt Hypex amp for around the same cost as a single (mono) PMC amp. I did 8-) And i've been perfectly pleased with it.
forumuser695516
Postby Kwackman » Wed Dec 07, 2011 7:21 pm
For the first time in ages there's a pair of Flying Moles on eBay- although one os described as faulty.
Strange coincidence.......
Kwackman
Postby ef37a » Thu Dec 08, 2011 3:18 pm
It is of little comfort to the OP I know but, this is the price you pay for "clever" technology.
It can be impossible to get repaired. I well remember the introduction of SMPSUs in TVs and later VCR. Many hours were often spent changing a score of components (many of which were afterthought "bodges" on the print side of the pcb!) only to have the thing burn up on switch on (and yes Cclogs, we used variacs and lamps!)How many SMPS's failed in say 1000 rental VCRs? Scores a year*. How many 50Hz traffs? Essentially none. A "digital" power amp is really just a very fast SMPSU with a speaker as the load!
I will agree that SMPUs as used for laptop supplies, monitor power etc are now very mature and reliable technology (which is just as well because nobody coulds mend t'buggers!)but I have long felt that those that profit from the sale of expensive electronic equipment should be made to make service provision of some sort.
*Did NOT like thunderstorms!
Postby James Perrett » Thu Dec 08, 2011 3:53 pm
That's the thing with the Hypex amps Dave - if they give problems then I (and probably quite a few others) know where to find the designer ;)
James.
Postby ef37a » Thu Dec 08, 2011 5:48 pm
James Perrett wrote:That's the thing with the Hypex amps Dave - if they give problems then I (and probably quite a few others) know where to find the designer ;)
James.
Well that's fine for "The boys in the know" but I want a decent service system for everyone.
We cannot simply go on making new stuff badly when the old stuff breaks.
Postby dmills » Thu Dec 08, 2011 6:15 pm
He is not exactly hard to find, but I agree and what I would like is a schematic actually in the supplied user documentation (For everything!).
The user does not need to understand it, but it makes the thing repairable by any competent tech.
And as for the IP argument, there is usually nothing that a competent reverse engineering team can not figure out quickly anyway.
It used to be the case that a lot of older hifi gear actually had a schematic glued to the inside of the case, made repairs very straight forward.
Regards, Dan.
dmills
Postby Folderol » Thu Dec 08, 2011 8:30 pm
I think it was Sony that was the first to not provide schematics. They were certainly the first to not give information to service departments that were not their official franchises. Now it's spreading into industrial kit. A lot of the modern machinery has no service information, or deliberately misses out critical stuff so on-site engineers can only do basic repairs.
One Manufacturing Bugger Off-er has nice error codes for all the system faults, but won't tell you what they are :x
Postby ef37a » Thu Dec 08, 2011 9:26 pm
I entirely agree with you Will. I too remember schematics inside equipment or foldout sheets in the instruction handbook. Geez! Nagra used to supply a small poly bag of components!
There is one small problem that I see. My last employer spent a lot of time,midnight oil, fags tea and bad language getting voicing circuits right. They are still a small company and fear all that work, if in the public domain, would be copied.
My personal view is that the more "professional" approach of giving out circuits to people who can show a genuine need is the best policy. The likes of Bellringers have the wherewithall to rip anybodies design, maps or no maps.
Postby Jack Ruston » Thu Dec 08, 2011 10:19 pm
Dan, I've just ordered an amp from classdaudio.com. It was 600 dollars and I'm told by a reliable source that it's 'amazing'. I will check it out and let you know. If it's good, it might be a worthwhile solution.
J
Jack Ruston
Postby dmills » Fri Dec 09, 2011 2:02 am
Dave,
given a working amplifier, do you really think it would take me (or any halfways competent analogue 'tronics type) more then about a day or 3 to rev. eng. the voicing networks.
Getting them empirically right might be tediously tweaky, but the netwoks themselves are rarely anything massively complex.
And yea, the usual suspects have plenty of analogue expertise on hand if they need it.
Regards, Dan.
dmills
Postby . . . Delete This User . . . » Fri Dec 09, 2011 2:26 am
i'm quite impressed by some offerings from Ground sound
http://www.groundsound.com/
Postby ef37a » Fri Dec 09, 2011 8:53 am
dmills wrote:Dave,
Regards, Dan.
No Dan I do not think that. My point is that the company PERCEPTION is that circuits will be copied and that is why they don't stick a schematic in every cab.
My personal view is that circuit information should be readily available and for other reasons than just the service man's convienience.
And if a "certain" company wants to rip the works, at least they will have to buy an amp first! But then it has long been page one, book one of the electronics designers bible, "See how the other buggers did it first".
Postby Martin Walker » Fri Dec 09, 2011 2:30 pm
Jack Ruston wrote:Dan, I've just ordered an amp from classdaudio.com. It was 600 dollars and I'm told by a reliable source that it's 'amazing'. I will check it out and let you know. If it's good, it might be a worthwhile solution.
J
That sounds most interesting Jack - looking forward to your feedback 8-)
