DIY Studio Build Diary
Re: DIY Studio Build Diary
Postby thefruitfarmer » Sun Jun 23, 2013 9:29 am
thefruitfarmer wrote:
Helmutcrab wrote:
The amount of time and money it is taking to d.i.y is just not worth it at all unless you like to d.i.y as a hobby. Making these panels as opposed to buying them has taken many months off getting music actually done.
That can be a problem sure enough.
What I have found is that I can manufacture a bass trap in a fairly short time. But, that is with my assembly method practiced and understood, and with all the right tools; I have corner clamps, two drills, a work bench, staple gun.
It is just a frame around a Rockwool slab, with chicken wire on the face, sprayed with a PVA solution and then covered with fabric. It sounds easy when you put it like that but like many things experience counts for a lot.....
...it is worth costing up all the materials of the traps and then factoring in your time as well it may well be worth buying ready made traps.
That said, I have 4 slabs of 25mm RW3 to turn into bass traps today so I will start a thread and see how long it actually takes me to do.
Build thread here.
That should read 4 slabs of 50mm RW3.
After about 6 hours I have 3 framed RW slabs sprayed with PVA solution and waiting to dry, which could take a few days with this cool and humid weather...
thefruitfarmer
Postby Hugh Robjohns » Sun Jun 23, 2013 10:58 am
Scramble wrote:>sprayed with a PVA solution
Does that not reduce the effectiveness of absorbing higher-end frequencies though? (Not an issue if you're just after bass-trapping, of course).
Technically, yes, but practically it is negligible, and most rooms are seriously over-damped at HF anyway so its actually a useful thing in most cases! The benefits far outweigh the negatives.
Postby Helmutcrab » Sun Jun 23, 2013 5:11 pm
thefruitfarmer,
Thanks for the new thread. Having a workspace in doors to build in is a god send. If i could have worked inside i would have finished a long time ago with my build. Unfortunately working outside with rock wool and paper is not possible in the rain or strong winds and this has been my main stumbling block regarding how long it is taking.
Like you say once you have learned how to build them it doesn't take as long, but if you factor in all time spent from the start - research, planning, sourcing, ordering and collecting materials, learning how to build the panels and getting the right tools and upholstering panels ( and days lost due to weather in my case ) it all adds up to a considerable amount of time. At least i can build a good air gap ( 6" posts/legs ) into the structure of my wall mounted panels to secure them to the walls by building them myself and will have more surface area covered and by thicker panels than if i had bought commercial traps ( on a budget ).
Hugh,
Thanks for reminding me about not overdamping the highs. I know you have worked in a lot of rooms so i will try to keep the panels paper faced whenever not in direct reflection paths.
Cheers,
Peter
Helmutcrab
Postby Helmutcrab » Thu Jun 27, 2013 5:05 pm
Hi all,
It was taking too long to use chicken wire on both sides so only the bottom corner panels have this. For some of the top panels i used heavy duty twine to bring in the sides when the wood had warped outwards.
To secure the panels to the walls i used 30mm eye screws from screwfix, one on each side ( slightly in from the sides so panels can be flush with the walls ) and a large eye hook/screw attached to the wood frame behind the plasterboard in the room corner. I then used this Hanging cord http://www.ukpictureframingsupplies.co.uk/low-stretch-picture-hanging-cord-no-3---sold-per-metre-167-p.asp I fastened a knot at one eye screw, then fed the cord though the wall hook and made a bow and knot. I fed a cable tie through this knot and the eye screw and pulled the tie till panel was secure.
These are the panels as you walk into room. The bottom panel has a double wall mounted socket obstructing it from being flush with the wall so it juts out a little on one side. This is were the vocal area will be so the bottom panel is paper faced with 4oz wadding in front but the top panel has the paper to the rear so the front is fully absorbing.
This is the next corner area as you go into room and is where drums will sit. I used paper faced panels with wadding in front to get the best balance of low end absorption but still taking the high's out to prevent some of the reflections. The room is still congested with materials for building panels and gear. Unfortunately i didn't have any storage facility which has made it more time consuming, having to move things around.
The mixing area will have a lot of fully absorbent panels around the mixing position so for both sets of corner panels here i used paper facing but this time i did not use wadding in front to allow for some reflections from behind the speakers so as not to leave the mixing position too dead.
At 6ft 11", the shortest corner in the room did not allow for two full panels so i made a shorter top panel.
Tomorrow i am putting the first wall/ceiling corner panel up. Sorry photo's are a bit dark.
I haven't done any tests yet but i think the room already seems a little better balanced.
Cheers
Helmutcrab
Postby thefruitfarmer » Fri Jun 28, 2013 11:57 am
Cheers
It's all looking very neat and tidy in there.
Did you fit these panels on your own?
You may need an assistant to fit the wall/ceiling panels.
I have done this on my own, but it is *so* much easier as a 2 man job.
thefruitfarmer
Postby Helmutcrab » Fri Jun 28, 2013 2:28 pm
HI thefruitfarmer,
Cheers, yes i fit the corner panels myself but my dad is helping me to do the rest, can't today though unfortunately :frown:
Thanks for the tidy comment - one of the first i've ever had :) You should see the rest of the room ! ( just way too much unused old stuff in there i need to get rid of ).
Honestly, i don't know how you did wall or ceiling panels yourself - thats some achievement.
Will get a picture up next week once its done.
Peter
Helmutcrab
Postby thefruitfarmer » Sat Jun 29, 2013 7:59 am
It was possible to fit a ceiling/wall trap myself, I had to use a stack of boxes to support one end.
So much easier as a two man job.
thefruitfarmer
Postby Helmutcrab » Thu Jul 04, 2013 11:39 am
Thanks for that link, i was looking for it when i fitted my wall-ceiling panel. That looked hard work.
I am fitting 6" spacers ( 4 per panel ) on to my wall mounted panels at the moment. They are same as frames ie 20 x 20mm. I am wondering if i should just glue them to the frames after they are made with no more nails glue. I have built one into the frame to give it a little more support. Problem is i can only use one screw per spacer from frame to spacer with wood glue, but if they snap when knocked or fitting it may snap the frame of the panel as well as the spacer, where as if i just glue them after, if they snap off they can just be reattached. The one i've built into the frame doesn't have much more strength anyway as it is just using one screw and glue. Any ideas ?
Helmutcrab
Postby Helmutcrab » Fri Jul 05, 2013 4:58 pm
Here is the first wall-ceiling panel in place ( again 6" deep panel ). This again is paper faced without wadding to give some high reflections back into mixing area. The panel is behind the speakers so is not in the reflection free zone.
This was quite difficult to fit even with two people due to the parallel placement of the ceiling joists and the sloping of the wall-ceiling. I think fitting the rest of the wall-ceiling panels will be easier ( i hope ), as the joists run perpendicular to the walls everywhere else in the room.
I used the same method of attachment as for the upright panels except i used two large ceiling 75mm eye screws ( ceiling is double plasterboard) near both sides and four 30mm eye screws on the panel itself spaced 100mm in from the edges so as not to be visible. Although the panel is solid, with hindsight i should have used 40mm eye screws on the panel to prevent failures. I will be doing this on remaining panels i think. Although the 30mm eye screws seem solid enough, they just look way to small for the job and a failure would be disastrous !
This is the first part of a wall mounted panel with 150mm wall spacers built into the frame. The middle two frame supports are yet to be added on this one.
I decided to build them into frame to give more support. I used one larger screw (50mm x 4mm) and wood glue to attach them from inside the frame, this gave enough support without having to use two smaller screws. Should the spacer ever snap i should be able to screw on a replacement one as long as the frame is not damaged.
This was a bit time consuming to do as i had to add on to the table top workbench Jig i made to accommodate for the now 30cm width of the panels. I don't think this would be a problem with a dedicated workbench.
I looked into screw on door stoppers but found them relatively expensive compared to d.i.y wood and they only seemed to come in a maximum of 4" and i wanted 6" for better performance.
Cheers
Helmutcrab
Postby Helmutcrab » Tue Jul 09, 2013 4:23 pm
Here is a finished frame with 150mm ( 6" ) spacers. Seemed solid on wall when i tried it. Will be hung from ceiling beams though as wall is not particularly weight bearing. Will use blu-tac or no more nails just to keep in place on wall, should it get knocked.
Cheers
Helmutcrab
Postby Helmutcrab » Thu Jul 11, 2013 4:16 pm
Finished another 8 frames ready for rock wool etc.
I have been wondering why it is taking me so long to build and i realised today that i have probably been over engineering these wooden frames for peace of mind. For a frame with spacers on, it takes 76 screws per frame, so thats 76 x countersinks, drills and screws plus gluing ( very messy ).
With 6" panels, using full thickness planks of wood was never an option due to price, but i'm pretty sure i could have saved a lot of time by using only 44 screws instead. Problem was i just didn't want to risk it as if the corner joins failed it would ruin the panel and it would also be using single screws for the individual frame joins ( not good ) and so relying on glue to maintain position once dried.
I will be fitting the rock wool, chicken wire, paper, wadding and hessian next week.
I think another 4 panels for ceiling clouds ( drums and mixing area ) plus one more for side wall ( which is very close to drums ) will do it. Thats 22 in total. Once these are up i will be able to see if i need any more. I also have some old 2" acoustic foam tiles that i can use once the panels are up if needed.
Cheers.
Helmutcrab
Postby Helmutcrab » Fri Jul 26, 2013 9:56 am
Finished 9 panels but after listening, the panels on the back wall with paper facing and wadding still reflect too much mids and highs for drum recording/acoustic instruments and they are close to instruments with their spacers on. Kind of got lost a bit and forgot i needed the back wall as dead as possible for this reason ( room is also asymmetrical and i aim to use convolution reverbs extensively ). So, i am redoing six panels and turning around the corner panels here and reupholstering them so they have full absorption.
I also realised why the paper was wrinkling up on the panels. I have been applying the spray glue for the paper wrong ( thanks to Steve2701 over on Ethan Winers Forum for explaining this ) which isn't a big deal but will reduce the effectiveness of paper faced panels at absorbing the lows.
For the record, you only need to spray a fine spray and let the glue go almost off - sticks upon touch - i didn't stick to the directions :headbang:
I am concerned the room will be too dead now as the only panels i can have with reflections ( all paper faced ) are those on the wall behind the monitors ( mixing position ). Everywhere else there will now be full absorption. I suppose there will be some life at the mixing position, where i need it.
Cheers
Helmutcrab
Postby thefruitfarmer » Fri Jul 26, 2013 12:12 pm
When you have a small room or with an unusual shape the advice I had at one point was to make it as dead as possible...on the grounds that any reflections won't be conducive to mixing. I reckon you would need a room that sounds good anyway if you are going to go for a more reflective mixing room.
A very dead room is still useable, you can still mix in it but there is some danger you will add too much reverb and echo. When this happens and a track is played in a living room it will have too much verb on it, bearing in mind that you are hearing it with the reverb of the living room also......
.. in practice it is not a problem if you listen to reference material in the studio.
If the room is very dead it can be good for recording vocals in but what I find is that acoustic guitars, a miced guitar amp, shakers etc all benefit from being recorded with some room reflections too.
thefruitfarmer
Postby Helmutcrab » Fri Jul 26, 2013 1:51 pm
Hi fruit,
I was told by Ethan Winer that any panels close to instruments or microphones should not be reflective at all. Somehow i lost sight of that but am changing the panels now. He also said panels that are out of the RFZ or first reflection points can be paper faced to help at the mixing position. In my room, this only translates to the wall behind the speakers, so i have used paper facing on all the panels behind the speakers and whilst the paper won't be doing that much useful to help bass ( as i glued them wrong ) they do add a really nice air to the mixing area which hopefully will stop it from sounding completely dead once these next lot of panels are in place.
Yes, i also found some early reflections helped with acoustic guitar and cello. I used a wooden board underneath the performer for this - which i am now using as the work bench to build these panels !
Thanks again for your advice, its always much appreciated :)
Cheers
Helmutcrab
Postby Helmutcrab » Mon Jul 29, 2013 10:54 pm
Iv'e changed those panels around but have misplaced my camera charger, so i will get photos of them on the walls as soon as i can.
I am now thinking about the overhead drum cloud. I plan on making three 2' x 4' panels at 6" depth over the drums, but the ceiling slopes from just under 9 feet on one side of the room to 7 feet at its lowest on the other side. The panels would intersect the transverse crossbeam rafter where it is 7'2" high. Using 6' panels therefore only allows a standing height of 6'8". This is where you have to walk into the room as well, so it may seem a bit oppressive. The panels will have to be tight on the ceiling at this lowest height, but will stay horizontal across to the other side of the room so most of the area will have a variable air gap behind the panels.
Now i am no giant but 6'8" seems a bit low. If i make 6" panels then there is no going back.
I am assuming that this is enough height for overheads, but i don't know. I think i might have to get things set up first to see if this height is enough to prevent overhead mic overloads and give enough height for the right placement. I will be using ribbon mics for overheads which i have not had much previous experience with.
Does anyone have advice on drum cloud height and also on its back to front position eg is it best to at least cover the area the drums and cymbals occupy ?
Peter
Helmutcrab
