Price of RW3 Rockwool...
Re: Price of RW3 Rockwool...
Postby Logarhythm » Sun Sep 15, 2019 1:57 pm
blinddrew wrote:Just under 16kg for the pack so about 35kg/m3.
Not enough irritatingly. Will give Jewson a call on monday but not sure if they sell direct to the public?
Ho hum. Didn't expect this to be easy but thought this bit might be a bit easier! :)
Jewsons definitely do - I cycle past the Exeter branch most days, and they have an enormous sign hung on their fence advertising exactly this.
Logarhythm
Postby blinddrew » Sun Sep 15, 2019 4:36 pm
Cheers, will give them a call tomorrow. Should be getting a quote from Selco as well.
P.S. Wonks, I'm ignoring that... ;)
Postby Hugh Robjohns » Sun Sep 15, 2019 4:41 pm
The density of RW3 is 60kg/m3 whereas RWA45 is 45kg/m3. Both are available in various thicknesses from 25 to 100mm and the sheets are generally all 600/1200mm wide/long. Both are class A1 non-combustible, of course.
It's frustrating, but understandable that most building suppliers insist on selling pallet loads, which is a lot of rockwool! And shipping will always be pricey because it is both bulky and heavy... But you can always put the left-overs in the loft! ;-)
For the Studio SOS jobs we generally use Rockwool Sound Insulation Slab packs from Wickes just because it's always in stock and can be bought in small quantities of one or two packs etc...but I'm not sure of its density to be honest... and the website doesn't seem to say.
Postby Sam Spoons » Sun Sep 15, 2019 4:55 pm
Drew is referring to Rockwool Sound Insulation Slabs https://www.selcobw.com/products/insulation/acoustic-insulation/rockwool-sound-insulation-slab-1200-x-600-x-50mm-8-64m
Maybe we get a little too anal about the specifics sometimes :blush:
Postby blinddrew » Sun Sep 15, 2019 5:14 pm
Sam Spoons wrote:Maybe we get a little too anal about the specifics sometimes :blush:
Yeah, I did wonder about that. And then I thought, "but I only want to do this once. And furthermore, if Max says 60kg/m3 is the best compromise, then I'm not going to argue." :D
Postby Music Wolf » Sun Sep 15, 2019 5:38 pm
I'm pretty sure that I got mine from Insulation Express and paid a delivery fee as it was still the cheapest alternative. Just spend a little time thinking through how you will use it so that you only need to order the once.
Music Wolf
Postby blinddrew » Sun Sep 15, 2019 6:02 pm
Music Wolf wrote:I'm pretty sure that I got mine from Insulation Express and paid a delivery fee as it was still the cheapest alternative. Just spend a little time thinking through how you will use it so that you only need to order the once.
They're on my list to call tomorrow, the added complication (because there wasn't enough beforehand) is that my road has a low bridge at both ends, so I need to find out how big their delivery lorries are.
I'm confident on my amounts though.
Probably.
Postby Sam Spoons » Sun Sep 15, 2019 6:15 pm
:thumbup: :thumbup: :thumbup:
That was my take so I went to some trouble to get the RW3 variant. TBF the higher density stuff is easier to work with too.
Postby Hugh Robjohns » Mon Sep 16, 2019 9:22 am
I've just had it confirmed from Rockwool themselves. The 'Sound Insulation Slab' product which you see in Wickes and elsewhere has a density of 35kg/m3 which is okay-ish for broadband absorption panels but not ideal for corner bass traps.
Postby blinddrew » Mon Sep 16, 2019 9:36 am
Funnily enough I've just had an email from them this morning as well. But mine said it was 45kg/m3...
Either way, I've got some phone calls about RW3 to make today. Cheers Hugh.
Postby Hugh Robjohns » Mon Sep 16, 2019 10:11 am
Hmmm... I think they make so many different products with such similar names that anything is possible. I asked about "Sound Insulation Slab" (product 180891, 400x1200x100mm) which is what Wickes current sell. And the reply was:
Rockwool UK wrote:Donna Lewis (Support - ROCKWOOL Limited)
16 Sep, 7:27 am BST
Good Morning,
The Sound Insulation Slab is 35Kg/m3 in density.
I hope this helps.
Many Thanks and Kind Regards,
Donna M. Lewis
Technical Solutions Consultant
Postby Wonks » Mon Sep 16, 2019 10:27 am
Ah, good-old reliable 35 kelvin gram rockwool.
Postby blinddrew » Mon Sep 16, 2019 10:52 am
Ah, I asked about 180889, to which i got the following response:
"The code you have mentioned below is Sound Insulation slab which is the equivalent to the RWA45, if you require the RW3 which is a 60kg slab then please quote 181186 ( im assuming you require 100mm thick slab) .
Thanks Nat"
Obviously not just the size that's different.
Postby Hugh Robjohns » Mon Sep 16, 2019 11:34 am
Weird! :headbang:
Postby blinddrew » Mon Sep 16, 2019 1:59 pm
Insulation Express's lorries are too tall. :(
However it looks like Jewson can do me a special order - but will take a fortnight.
Definitely making progress!
Will see what Selco can do tomorrow. :)
