New Studio Build - Summerly Studios
Re: New Studio Build - Summerly Studios
Postby Wonks » Tue May 22, 2018 12:20 pm
But you'd still need a fresh air supply, and that, though small, could cause problems when its cold outside if it wasn't at least heated. You could have used a packaged heat exchanger unit complete with fans to minimise any temperature impact , but you'd still need somewhere to put it out of the way and you'd need attenuators (though smaller).
Postby Tonyes335 » Sat Mar 02, 2019 4:36 pm
Control room being boarded with it’s OSB layer. This was followed with 3 layers of plasterboard and has now been plastered and painted. Every layer caulked etc.
The following link should lead to images of the room in it’s current state and the final dimensions. I just need to make the bass traps and put in the glass which is due Monday 4th Mar. On the ticket the total glass weight was well over 1/2 tonne for the 4 openings. That will be a combination of 12.8,10.8 and 8.8mm acoustic laminate.
Once the bass traps are done I will cover with fabric and the same goes for the ceiling.
I ended up outsourcing the acoustic panels as I needed quite a few. They should be with me 11 March.
The live room is also nearly done so will update on that soon.
https://www.amazon.co.uk/photos/share/Db1izmFs8KlTGbBdsYMprdHxPuJvLY4NAgNgVzsnlCf
Tonyes335
This diary also on Facebook page @summerlystudios
Postby Tonyes335 » Sun May 26, 2019 5:50 pm
Attached are images of the live room. It is set up for a film screening in these photos. Just a couple of cupboard doors and acoustic panels to add and it is finally done. Subjectively the room sounds great and with a film playing full blast there is minimal low frequency noticeable outside which exceeded my expectations as I still need to seal the loft hatch access which is effectively a 900mmx600mm opening in the outer shell at the moment
The control room is finished but I am still not decided on the final equipment selection at the moment. Again the room sounds fine in the sweet spot. I need to add the final door seals and I can report on the room to room isolation.
https://www.amazon.co.uk/photos/share/o ... EAILojA5e2
Cheers, T
Tonyes335
Postby Folderol » Sun May 26, 2019 7:35 pm
That look really nice. it also looks rather comfy :bouncy: :thumbup:
Yes. I am that Linux nut.
Postby blinddrew » Sun May 26, 2019 9:31 pm
Looks inspiring. :)
Postby jaminem » Tue May 28, 2019 2:36 pm
That looks fantastic, can't wait to see the control room....
jaminem
Postby Watchmaker » Tue May 28, 2019 4:09 pm
I notice a bottle of scotch on the mantle. You've thought of everything! looks brilliant!
Watchmaker
Postby hicksjay » Wed Sep 25, 2019 4:34 am
Love this.
Just joined today as the new home I'm constructing for me and the wife is going to have a live play/recording living room in it.
hicksjay
Postby Wonks » Wed Sep 25, 2019 10:15 am
hicksjay wrote:Love this.
Welcome to the forum.
Why not create your own construction diary here? We'd all be interested.
