New Studio Build - Summerly Studios
Re: New Studio Build - Summerly Studios
Postby Wonks » Tue May 22, 2018 11:20 am
But you'd still need a fresh air supply, and that, though small, could cause problems when its cold outside if it wasn't at least heated. You could have used a packaged heat exchanger unit complete with fans to minimise any temperature impact , but you'd still need somewhere to put it out of the way and you'd need attenuators (though smaller).
Postby Tonyes335 » Sat Mar 02, 2019 3:36 pm
Control room being boarded with it’s OSB layer. This was followed with 3 layers of plasterboard and has now been plastered and painted. Every layer caulked etc.
The following link should lead to images of the room in it’s current state and the final dimensions. I just need to make the bass traps and put in the glass which is due Monday 4th Mar. On the ticket the total glass weight was well over 1/2 tonne for the 4 openings. That will be a combination of 12.8,10.8 and 8.8mm acoustic laminate.
Once the bass traps are done I will cover with fabric and the same goes for the ceiling.
I ended up outsourcing the acoustic panels as I needed quite a few. They should be with me 11 March.
The live room is also nearly done so will update on that soon.
https://www.amazon.co.uk/photos/share/Db1izmFs8KlTGbBdsYMprdHxPuJvLY4NAgNgVzsnlCf
Tonyes335
This diary also on Facebook page @summerlystudios
Postby Tonyes335 » Sun May 26, 2019 4:50 pm
Attached are images of the live room. It is set up for a film screening in these photos. Just a couple of cupboard doors and acoustic panels to add and it is finally done. Subjectively the room sounds great and with a film playing full blast there is minimal low frequency noticeable outside which exceeded my expectations as I still need to seal the loft hatch access which is effectively a 900mmx600mm opening in the outer shell at the moment
The control room is finished but I am still not decided on the final equipment selection at the moment. Again the room sounds fine in the sweet spot. I need to add the final door seals and I can report on the room to room isolation.
https://www.amazon.co.uk/photos/share/o ... EAILojA5e2
Cheers, T
Tonyes335
Postby Folderol » Sun May 26, 2019 6:35 pm
That look really nice. it also looks rather comfy :bouncy: :thumbup:
Yes. I am that Linux nut.
Postby blinddrew » Sun May 26, 2019 8:31 pm
Looks inspiring. :)
Postby jaminem » Tue May 28, 2019 1:36 pm
That looks fantastic, can't wait to see the control room....
jaminem
Postby Watchmaker » Tue May 28, 2019 3:09 pm
I notice a bottle of scotch on the mantle. You've thought of everything! looks brilliant!
Watchmaker
Postby hicksjay » Wed Sep 25, 2019 3:34 am
Love this.
Just joined today as the new home I'm constructing for me and the wife is going to have a live play/recording living room in it.
hicksjay
Postby Wonks » Wed Sep 25, 2019 9:15 am
hicksjay wrote:Love this.
Welcome to the forum.
Why not create your own construction diary here? We'd all be interested.
Postby jeffbruckner » Sat Jan 04, 2020 11:55 pm
Best of luck with the design / build me old mucker.
After many years of engineering/producing with and without daylight,
can't remember any sessions that were better or worse, with or without windows.
I do remember loving every second.
There are no rules. Design for comfort , practicality and creativity.
Design a place that works and where you want to be.
Jeff
jeffbruckner
Postby William87 » Sun Jan 26, 2020 12:48 pm
Hi!
What kind of acoustic panel recommend me?
William87
Postby Folderol » Sun Jan 26, 2020 2:02 pm
jeffbruckner wrote:Design a place that works and where you want to be.
Well said (and welcome). The above line is the most important!
Postby Sam Spoons » Sun Jan 26, 2020 2:58 pm
William87 wrote:Hi!
You could do worse than buy from these people https://gikacoustics.co.uk. Other brands are also available
But, there are loads of threads in these forums with detailed info on how to DIY, or what to buy, as well as regular "Studio SOS" articles in the magazine which frequently have to deal with room acoustics.
Postby William87 » Mon Jan 27, 2020 11:20 pm
Sam Spoons wrote:
William87 wrote:Hi!
I was thinking of this acoustic panel:
https://perfect-acoustic.com/termek/classic-sound-absorber/
William87
Postby Sam Spoons » Tue Jan 28, 2020 12:02 pm
You will need some broadband absorbers too, and the claims they make of absorption down to 40Hz will most likely only apply to the 110mm thick panels spaced 100mm off the wall which takes up a fair amount of space in a small room. Detailed info is a bit sketchy on their website though.
Postby AudioPhilisopher » Thu Feb 13, 2020 4:30 pm
Wowzer, that's a build to envy. I wish I had the space and budget to build something like this.
I know the thread is old, it's a shame the pics were deleted. I wanted to see what the final build looked like,
Also how was the sound insulation?
My dream would be to build an underground studio, sort of like how colin furze made his underground bunker (although he has stupid amounts of Youtube money to do whatever he wants).
I reckon you could have a drummer in his bunker and you wouldn't hear a thing.
AudioPhilisopher
Postby Eddy Deegan » Thu Feb 13, 2020 11:47 pm
AudioPhilisopher wrote:My dream would be to build an underground studio, sort of like how colin furze made his underground bunker (although he has stupid amounts of Youtube money to do whatever he wants).
Acoustically, I agree. Also it's undeniably extremely cool :-)
If I recall correctly, it wasn't youtube money that paid for his extraordinary underground bunker but Sky sponsership. More power to his elbow, his content is brilliant!
In my case I use studio space not only for engineering but for inspiration, so being underground in a room without a window that has a nice view would feel a bit weird. not that my current space has such a view but I've always considered that a massive compromise and I'm hatching plans to mitigate that.
If that wasn't a consideration though...
Some of my works.
