Need help measuring response of an L- shaped room
Postby jjitter » Wed Jan 03, 2018 4:50 pm
Hello all,
I finally have a budget to get a measurement microphone and get some acoustics done with the help of REW for my home mixing studio. Below is a picture of the room layout and the mixing spot as of now.
But I was really wondering wether that a good spot to start measuring? Do I have a better chance of good acoustics facing some other wall?
Just wanted some advice before I start measuring for the first time.
Thank you! Any help will be appreciated.
jjitter
Re: Need help measuring response of an L- shaped room
Postby Hugh Robjohns » Wed Jan 03, 2018 5:51 pm
I think that's the optimum setup for that room. You're working along a long dimension, which is good, and you have a reasonably symmetrical region (in terms of walls and surfaces) around the monitors and listening position, which is also good.
Postby jjitter » Fri Jan 05, 2018 4:36 pm
Hi Hugh,
Feel kind of relieved when you say that. Had been wondering if an L-shaped room can ever get close to a rectangular room in terms of acoustics. The mix spot is at around 40% of the room length. Room length = 3.9m, mix spot distance from front wall =1.5m.
Will make a relevant thread for a few other measurement related questions.
Thanks!
jjitter
Users browsing this forum: MOF
