4 octave weighted keyboard
Postby Shindig » Sun May 13, 2018 1:10 pm
I'm looking for someone to build me a custom 4 octave weighted digital piano. I imagine this will be something cut down from an 88 or 76 note.
I can make a new wooden custom case, but I need someone to look after the overall design, and electronic aspect.
Anyone out there interested in this?
Shindig
Re: 4 octave weighted keyboard
Postby resistorman » Mon May 14, 2018 5:08 am
An interesting idea. Keyboards I’ve worked on have 3 or 4 circuit boards under the keys. You really wouldn’t want to cut those, so you would have to accept whatever that range turns out to be once you take out a couple.
resistorman
future26.com
Postby Martin Walker » Mon May 14, 2018 3:10 pm
Sounds like this is going to be an expensive project Shindig, especially if resistorman is correct and you have to abandon one or more 76/88-note keyboards to find one that's suitable for cutting down! :headbang:
Postby Shindig » Tue May 15, 2018 12:02 am
Yes, thanks for the reality hit resistorman!
I'm looking into trying a 49 key "semi-weighted" controller instead now. if the Akai MPK 249 feels ok, it would be perfect, because it has no wheels/sliders/pads at the side of the keyboard.
I could pair it with a classy iPad piano app, and a pair of bi-amped speakers...
Shindig
Postby Martin Walker » Tue May 15, 2018 9:30 am
That sounds a lot more feasible Shindig! :clap:
Good luck!
Postby Shindig » Mon May 21, 2018 5:28 pm
I've decided on an Akai MPK49, as it has no wheels, knobs or slides to the side of the keyboard, making it the narrowest option available.
And I've listened to most of the iPhone/ipad offerings, and I quite like ivory, ravenscroft and some from Colossus. I'm after a warm sounding instrument, ideally like a Bluthner, though that sort of sound doesn't seem to be in much demand these days...
The next thing is a pair of small active monitors, which I'll place on either side, facing upward (towards the ceiling), so I can hear as well as the audience. I could do with any suggestions for these - something compact, maybe not too bright, though I'm sure I can make adjustments in the app...
I've noticed the Genelec 8020Ds and KRK RP5s so far. Any thoughts on suitability?
Shindig
Postby blinddrew » Mon May 21, 2018 8:22 pm
Worth looking at the ilouds as well i'd suggest.
Postby Shindig » Tue May 22, 2018 12:48 am
Thanks blinddrew, I hadn't known about these
"the smallest active studio reference monitor system in the world, at just 180 x 135 x 90mm".
Definitely worth taking a look
Shindig
Postby blinddrew » Tue May 22, 2018 9:39 am
Don't expect miracles, the laws of physics still apply, but they've been well reviewed and i was very impressed when i heard them.
Postby Shindig » Wed May 23, 2018 8:21 pm
Ok, now I've decided to install an active loudspeaker instead of using studio monitors. I'd use two, but on a 4 octave keyboard there won't really be much room!
This is so I can cart it to small pubs etc, and play with other acoustic instruments, without worrying about destroying the nearfields.
I've done a ton of research, looking for speakers that can do a quality sampled piano some justice, and decided on a single RCF TT08A. Though it will be the Mark II, just about to come out.
Just need to decide where to place it...
Shindig
