Wanted: Amcron/Crown 300a Amplifier
Page 2 of 2
Re: Wanted: Amcron/Crown 300a Amplifier
PostPosted: Sun Aug 12, 2018 4:36 pm
donmarrese wrote:I have a 303 in fact I've had several... And I always sell them on... For me they don't come anywhere near the Tresham/Tannoy or and Amcron amps.
Not really surprising when you're comparing a 50W /8Ohm amp with others producing 150-250W /8Ohms!
The Quad 303 was quite outstanding in its day, compared to its peers at the time, and is still a creditable amp whenused with high sensitivity speakers (with a gentle impedance curve) or at relatively low listening levels -- but it's obviously not on a par with hefty MosFET monsters like the Tannoy... Or a Krell, or a Bryston...
...reason: a thread starts and so many times, it goes off at a tangent with a dialogue that has nothing to do with the core of the actual thread .....so he doesn't bother with forums....
Happens everyday in normal real life discussions too, I find...
PostPosted: Sun Aug 12, 2018 7:24 pm
by Trevor Johnson
Yes, apologies to the OP about going off at a tangent. The truth is that well engineered amps will always fetch good money because they can be fixed quite easily (with the exception of obtaining some rather rare Japanese mosfets). Even if the original amp has been destroyed, albeit unlikely, you can always use the case to build a new one in, as many people have done with 405s, etc..
Off tangentially again. I have a 303, a very late dark grey model with an IEC mains socket. I bought it from a well know Hi-Fi supplier, but on inspection and without powering up (!), found that one of the PSU electrolytics was short circuit and the right amplifier HT supply physically broken. Anyway, they were very good about it and gave me the money for new PSU caps; much less expensive than carriage back and forth! I fixed a few more things and it is a lovely amp, very clever circuit design, but as Hugh said, you need the right speakers to match it.
PostPosted: Sun Aug 12, 2018 8:12 pm
by donmarrese
Actually, I might as well go off at a tangent myself..what the
heck, join the club...
I do have an Amcron 300a that has blown an output transistor...can anyone recommend a electronics engineer to repair...has to be local as it weighs a bit..I'm based in North London...got some other bits to sort as well, like a quad 33 pre...and a valve amp..do you guys have a favourite repair guy?
Cheers
Sent from my ONE A2003 using Tapatalk
PostPosted: Mon Aug 13, 2018 4:57 pm
by donmarrese
Anyone?
PostPosted: Mon Aug 13, 2018 6:14 pm
by James Perrett
I think that Funky Junk have their own repair department but I'm sure that there are plenty of others. I know someone in Wembley who might be able to look at it.
http://www.michaelmauricerepairs.co.uk/
PostPosted: Mon Aug 13, 2018 6:31 pm
by donmarrese
Thank you all due respect to funky junk they aren't they are not how do you say competitive with the pricing thanks for the heads up anyway
PostPosted: Mon Aug 13, 2018 6:34 pm
I don't know anyone in the N.London area I'm afraid, but you could ask KMR for a recommendation.
As for the Quad 33, it would be worth contacting Quad themselves in Huntingdon. They offer a servicing facility which is very affordable and return the product in superb condition. Always gains very good feedback amongst the classic hi-fi fraternity.
PostPosted: Mon Aug 13, 2018 6:35 pm
by donmarrese
Yes, I was considering a run up the M11...been there before...cheers
PostPosted: Thu Aug 30, 2018 2:27 pm
by donmarrese
Hi James Perret, got in contact with michael maurice, you gave me link to his website... After a load of phone calls and emails the guy couldn't remember who I was or what I wanted so I gave up on him.... I'm sure it's been good to other people but for me, a waste of my time.
No reflection on yourself but thanks for the pointer it could have gone the other way..
PostPosted: Thu Aug 30, 2018 4:09 pm
by Phil Ward
All this Amcron DC300A talk takes me back to my early 1980s Mordaunt-Short speaker design engineer days. Bear with me, it's relevant :-)
One of my regular jobs back then was to analyse voice-coil wire and voice-coil to cone adhesives for temperature stability. One way of doing this was to blast DC through the coil and measure the resistance increase – from which the temperature of the coil could be derived with reasonable accuracy. We'd hang a weight off the voice-coil so it was pretty obvious when the adhesive began to soften.
The only snag was that we didn't own a decent variable DC power supply – well we didn't until we hit on the idea of plugging a 1.5V battery into the input of the Amcron DC300A that we used for speaker pink noise power testing. It worked perfectly. The DC300A never broke, or ever expressed even the mildest complaint, and I've respected it ever since as a really classy and basically unburstable example of power amp design.
P
PostPosted: Thu Aug 30, 2018 4:40 pm
by ef37a
Crazy days Phil! So, the lab did not have/could not afford a decent DC supply but you COULD run to a top grade amplifier and moreover were prepared to risk abusing it!
PostPosted: Thu Aug 30, 2018 4:51 pm
by Phil Ward
ef37a wrote:Crazy days Phil! So, the lab did not have/could not afford a decent DC supply but you COULD run to a top grade amplifier and moreover were prepared to risk abusing it!
Errrr, yeah, you could put it like that, but I like to see it as a triumph of pragmatism and a really cool power amplifier :-)
P
