My SMpro 4M passive monitor controller failing.
Postby Gone To Lunch » Sat Aug 11, 2018 12:25 pm
Is there anyone in or around London who could repair this ?
The actual fault is that one of the output channels has lost its signal, and the corresponding button on the front panel will no longer lock when pressed in. Signals are fine through other outputs.
Alternatively, any suggestions for its replacement ? It is now discontinued.
Gone To Lunch
Re: My SMpro 4M passive monitor controller failing.
Postby Hugh Robjohns » Sun Aug 12, 2018 4:41 pm
Sounds like it requires a replacement switch. Chances are it will be a standard type and replaceable by any capable electronics technician.
But if you're looking for a very hgh qualit but affordable monitor controller, my stock budget recommendation is any of Drawmer's CMC/MC offerings. They are very well-equipped, well-built, perform to very high standard, and sound transparent... And are available in a variety of sizes and formats.
http://Www.drawmer.com
Postby Gone To Lunch » Thu Aug 16, 2018 10:48 am
Hugh Robjohns wrote:Sounds like it requires a replacement switch. Chances are it will be a standard type and replaceable by any capable electronics technician.
Thanks Hugh.
Who would you recommend to do the repair in Greater London ?
Gone To Lunch
Postby Hugh Robjohns » Thu Aug 16, 2018 11:12 am
Sorry, I'm not familiar with technicians in that area... You could ask around the better music equipment retail shops, though, as they probably have tame technicians on their books.
Postby Gone To Lunch » Thu Aug 16, 2018 1:03 pm
Hugh Robjohns wrote:Sorry, I'm not familiar with technicians in that area... You could ask around the better music equipment retail shops, though, as they probably have tame technicians on their books.
StudioSpares have now put me in touch with a man who can...
Gone To Lunch
Postby Hugh Robjohns » Thu Aug 16, 2018 2:22 pm
:thumbup: :clap: :)
