The quoted 10 ms processing time doesn't seem 'blisteringly' fast to me. It's quick, but for a fretboard scanning device, I'd have expected something faster.
It suggests to me that they are possibly using the standard Graphtec piezo MIDI module in conjunction with a fretboard device that confirms the note selection to avoid mistriggering, rather than an all-new note detection system.
But I'm only guessing.
Yamaha G10 Repair
• Page 2 of 2 • 1, 2
Wonks - Jedi Poster
Re: Yamaha G10 Repair
The G10-to-G10C cable connector is Hirose RP13A-12PD-15SC(71), plus 14 (or 15 to populate every position of the connector) socket contacts, Hirose RP13A-SC-121. Currently, there appears to be no inventory is the US, although Mouser Electronics has some on order with an anticipated arrival of November 11:
https://www.mouser.com/ProductDetail/Hi ... wYsw%3D%3D
There is also a distributor in Hong Kong that shows some inventory, but I have not confirmed it.
You can make a cable, as I did, using these connectors and a suitable cable with enough conductors; I found an old printer cable that did the job. You must be very careful to trim and strip each of the conductors to be as close to the same length as possible.
- designer_14830
Users browsing this forum: DGL.
