USB extensions for remote gear in sound booth
Re: USB extensions for remote gear in sound booth
Postby Wonks » Fri Feb 08, 2019 1:34 pm
There are lots of cable makes, but finding one that makes consistently good quality cables is the problem. If that brand has always been 100% reliable for you (allowing for the fact that even the best cables will get damaged if misused or run over by the wheels on a chair etc.) then fine. But don't go by price alone.
Postby James Perrett » Fri Feb 08, 2019 2:58 pm
Startech stuff has usually been fine in my experience although I've not used their active USB cables. I guess finding Lindy cables may be a bit difficult where you are as they are a UK based company and I'm not sure who the US equivalent is.
Postby ef37a » Fri Feb 08, 2019 7:10 pm
I don't think you will have much trouble with a 10mtr run of USB except for the AI and for that you might find this is the answer? https://uk.farnell.com/newlink/usb-boos ... 9714695233
Yes, AIs can be fussy about hubs but my NI KA6 isn't. I can also run the KA6 from a 5mtr USB cable and also a Focusrite 8i6. If your AI has local power from a wall rat, voltage drop over the extension will not matter (in fact the drop will be very, very small anyway)
