Munro Egg 150 query
Re: Munro Egg 150 query
Postby blinddrew » Sun Feb 10, 2019 7:05 pm
Sadly that is always the way. Still, hopefully that will help you pinpoint the fix. :)
Postby Sam Spoons » Sun Feb 10, 2019 7:06 pm
At least you can send them back for a refund under the distance selling regs :thumbup:
Postby Wonks » Sun Feb 10, 2019 8:21 pm
It may be the amp output socket isn't quite right, so has then damaged the cable connector. Which may then happen to the new connector! Hard to tell without taking everything apart.
Postby ImdurC » Sat Aug 31, 2019 10:28 pm
I've just been going over some old posts I made and I suddenly realised, I never wrote a follow-up for this! Oops :tongue:
Long-story-short, the 4-pole cables I ordered worked perfectly! At this point, there was no difference between the speakers and cables -even when going back and forth between the two speakers and cables. Hurrah!
Anyway, I'm simply updating this post to show that replacing the old cables was the fix and nothing more was required! Since then, I've also bought a cheap set of Munro Egg speakers for parts. So, if anything goes wrong (touch wood), I'll always have replacements on-hand.
ImdurC
Postby Wonks » Sun Sep 01, 2019 7:13 am
Good to hear! :thumbup:
