10.5V PSU query
10.5V PSU query
Postby Kurtcat » Fri Feb 15, 2019 1:31 pm
Hi all,
I think this has sort of been answered before back in topic '10.5 volt power supply. Ummm...how?' started by Seaforth however i just want to make sure i am on the right track before i 'fry' something.
A good friend has given me a Quasimidi Rave O Lution 309 that was missing its original PSU. The input voltage was 10.5v (1.5amp). The same as Seaforth with his Quasimidi Polymorph trying to find a PSU with that rating is impossible.
Now i do have a 12v (1.5amp) PSU with correct polarity, any thoughts on whether this would be safe or not?
Kurtcat
Re: 10.5V PSU query
Postby Hugh Robjohns » Fri Feb 15, 2019 1:59 pm
Looking at the manual here: https://www.quasimidi.eu/index.php?option=com_jdownloads&Itemid=39&task=finish&cid=71&catid=1
...it states
quasimidi wrote:Take the included power supply out of the box. Plug the smaller coaxial plug into the jack on the rear of the 309 marked "10.5VDC/1.5A" (US: "12VDC/2A"). Plug the other end into a standard 230VAC (US: 120VAC) wall outlet.
So the question is, did they simply supply a different, third-party 12V PSU in the American market (possibly just because of getting the right FCC approvals), or did they actually fit different internal power rail components in the unit for the US market...
I suspect the former is the case, and that it will be absolutely fine with a 12V DC supply --provided it really is DC and wired with the right polarity and of sufficient amperage.
But as always... Caveat emptor...
Re: 10.5V PSU query
Postby Kurtcat » Fri Feb 15, 2019 2:30 pm
Thanks for reply, that is interesting regarding the manual, it may be that i just have to give it a go and see what happens.
Kurtcat
Re: 10.5V PSU query
Postby Kurtcat » Fri Feb 15, 2019 2:38 pm
Just an update, i've tried the 12v PSU and there were no loud bangs or flashes :D screen looks good, just about to connect to amp and see what i get.
Kurtcat
Re: 10.5V PSU query
Postby Hugh Robjohns » Fri Feb 15, 2019 3:23 pm
:thumbup: :D We need a fingers-crossed smilie!
Re: 10.5V PSU query
Postby Kurtcat » Fri Feb 15, 2019 3:57 pm
What can i say other than..........
IT'S A BEAUTIFUL THING :bouncy:
Thanks again for advice, seems to be working fine, good job i've got some time off work to have a play, it's fully modded so a nice piece of kit.
Kurtcat
