Attic Room Studio Build
Re: Attic Room Studio Build
Postby Luke W » Thu Aug 01, 2019 10:01 pm
Sam Spoons wrote:Excellent pictures Luke, and a lovely job all round. I had, sort of, planned to take more pics of my studio refurb but just got impatient to be getting on with the job :blush:
Thanks very much. I try to get as many as I can with most projects, I do tend to end up with some gaps where I got carried away and forgot to take some though.
Eddy Deegan wrote:Following with interest as I'll be doing something similar soon myself. The photos of the construction are really good to see :thumbup:
Glad it helps :thumbup:
Luke W
Techie / Musician Of Sorts
Postby Luke W » Thu Aug 01, 2019 10:29 pm
The next stage was some panels above the corner traps that came out at an angle to meet the window frame, although it's not much of an angle it meant I could get an extra 50mm of Rockwool in at the deepest end.
The start of a frame:
Test fit:
Rockwool in and frame fixed :
Shorter version for underneath:
Sides finished:
Luke W
Postby Hugh Robjohns » Fri Aug 02, 2019 8:59 am
Nice work, and I'm sure a lot of people will find the constructional images very helpful.
:thumbup: :clap:
Postby Luke W » Fri Aug 02, 2019 10:07 am
Cheers, Hugh. I hope so, I've found the forums very useful over the years so it'd be nice if some help could go back the other way for a change!
Onto the next stage, finishing the sloped ceiling panels. I wanted the edge of the panel to sit completely flush with the ceiling rather than be bordered by a timber frame, and the angle of the pitch roof made the cuts rather interesting. I started out by marking out where the panel should sit, and taking some measurements along where I wanted the braces to sit. I like just cracking on with a saw as much as the next person, but some planning and paper definitely helped here.
Marked out:
The simple half of the frame:
I then clamped that half in place, and double checked measurements for the braces.
Angles on the edge of the braces:
Because of the odd angles, I cut the braces slightly longer than necessary and then trimmed down the straight end once the angles were fitting nicely. This allowed a bit of room for error, and cutting off the other end at 90 degrees is a far simpler task than trying to shave a few mm off of the angle you've just got to sit nicely...
Another test fit with the braces attached, the longer one does fit, but gravity is doing its bit. Honest:
You can never have too many clamps:
A couple of shots with the rockwool in:
Final test fit:
These came back down as they were getting fixed together and placed up as one panel once I'd got the fabric on. I also got another few slabs of rockwool behind them before fixing them in, so at the deepest end theres around 250mm.
Luke W
Postby Folderol » Fri Aug 02, 2019 7:54 pm
That's some serious carpentry there - those angles would drive me off screaming :o
Postby Watchmaker » Fri Aug 02, 2019 8:40 pm
Luke W wrote:You can never have too many clamps:
Secret sauce 101.
Watchmaker
Postby Dennis J Wilkins » Sat Aug 03, 2019 4:49 am
Hi Luke,
Looks very nice and I expect it sounds fine. You've set up significant treatment symmetrically left to right, and the odd room/ceiling angles should help disperse standing waves. If you get a chance you should try Room EQ Wizard to view frequency and time domain performance. Really helps to see just what is going on at the primary listening position and a few feet around it. You might get some rear reflections from the windows which was an issue I had until I added the hanging panels I showed in the Studio SOS article in April (2019). It does cut out the nice view and natural light, but in my case I wanted the room light-tight for photo work, so I didn't mind! In your room, heavy drapes might do the trick if you find any comb filtering issues from rear reflections, and you could open it when you're noodling around with your guitars and don't need mix/mastering level room response.
I hope you really enjoy it!
Dennis J Wilkins
Dennis - Colorado USA
Postby Luke W » Sat Aug 03, 2019 11:30 am
Thanks, Dennis. I'm planning on giving REW a go out of interest, I'd like to have measured the room first as well to get a comparison but my lack of patience got the better of me. The window has got some curtains now, but any good that's done has probably been reversed by the two screens! I've made sure they're back behind the monitors as much as possible to minimise any issues, and it seems to be a good compromise. There's still two skylights in the rear wall/ceiling so natural light is still available.
Luke W
Postby Luke W » Sat Aug 03, 2019 11:31 am
Folderol wrote:That's some serious carpentry there - those angles would drive me off screaming :o
Thanks, I find that things like this always look more daunting than they are though. Measure twice and all that...
Luke W
Postby Luke W » Mon Aug 05, 2019 12:18 pm
Fabric time... Based on recommendations on here some general searching, I went for some Camira Cara fabric. It costs a little more than some of the alternatives, but it's really easy to work with and I think the finish makes it more than worth it. It also comes in a decent width so I ended up with very little waste.
A few of the panels and the traps didn't get any pictures taken as I got a bit carried away once I'd started the first one, but theres enough of the others to see what was going on.
Using an off-cut for one of the smaller panels (missing some Rockwool in this picture):
Front side:
One of the square panels:
Front of both square panels (the fold in the left one has since worked its way out):
Side panels all done:
Before the final fixing I gave the backs of the panels a spray with a mix of PVA/water to make sure no loose fibres went floating around.
Luke W
Postby OneWorld » Mon Aug 05, 2019 1:01 pm
Music Wolf wrote:That looks very neat. It certainly puts my DIY / woodworking skills to shame :sick:
Same here, no matter what I try all the wiring looks like an explosion in a spaghetti factory
OneWorld
Postby Sam Spoons » Mon Aug 05, 2019 3:16 pm
Good colour choice there Luke. :thumbup:
Postby Luke W » Mon Aug 05, 2019 4:53 pm
Sam Spoons wrote:Good colour choice there Luke. :thumbup:
Does it look a bit familiar?! :thumbup:
Luke W
Postby Luke W » Mon Aug 05, 2019 10:26 pm
Onto the ceiling panel fabric...
To get a nice edge on the outside of the ceiling panels I attached some thin moulding to the edge of the frames, held in place with some panel pins and glue. Once it had dried I cut the edges flush and sanded them over, making sure everything was nice and smooth so there wasn't any chance of tearing the fabric at the edges.
Glued up, waiting to dry:
Fabric stapled roughly into place:
Front side:
Once all three ceiling panels were covered I lined them up together and clamped the back edges, and fixed them together by screwing through the frames from the inside of the panel outwards, directly into the next frame. A few screws going either way made sure to clamp the panels tightly together, and left a neat join between them.
All three up, with a test fit for the cover plate that finishes up the edge of the panels:
You can also see the cable for a light fitting making its way through behind the panel. To mount a light fitting, I used a bit of 12mm MDF, and covered it with an off-cut of Cara.
Light fitting mount:
With everything fixed back up, the next job was to start framing up and working on some little finishing off bits for around the edges and ends of the various panels. I'll have another sort through some photos and hopefully get some of the next stage up tomorrow. :thumbup:
Luke W
Postby Luke W » Tue Aug 06, 2019 12:00 pm
This stage seems to have a few less pictures, but I've got some some showing how I got the finish on the wood, and a few various stages of the framing going up.
All of the wood I used was just standard softwood timber, a lot cheaper than using anything fancy. Once pieces were cut to length and fitting nicely I gave all the visible faces and edges a sand over (a fine grit paper was enough as planed timber is usually already fairly smooth), and then set about burning them with a blowtorch. This takes a bit of getting used to, once the flame is close enough the wood can go from "exaggerated grain" to simply just on fire rather quickly, I had a go on a few offcuts first to try and avoid having to make things again.
Half way:
Ready:
Two coats of dye rubbed in:
Fitted, after a coat of wax polish:
I also made an end panel to sit above this cover plate, and meet board the light is mounted on. It was another bit of spare MDF cut into shape with an offcut of Cara stapled around it, sized so that the cover plate being screwed in clamps it firmly into place.
Luke W
