Box room problem or benefit?
Re: Box room problem or benefit?
Postby Folderol » Mon Jan 27, 2020 11:37 am
The usual recommendation with artexed ceilings, is to put 9.5mm plasterboard over them - using screws, not nails so pretty much zero disturbance.
Postby Gmonics22 » Fri Jan 31, 2020 2:41 pm
Update:
So I managed to source a couple of double duvets, and tried them in various locations held up by a precarious arrangement of dining room chairs, curtain poles, a mop and a broom. I consider this a rite of passage. Placing on the side walls to cover first reflections seemed to be the most effective, massively reducing my 200hz honk. Happy days!
Well, this has created a dilemma. Before last night I'd settled on building 4 panels from 100mm Rockwool, 2 for first reflections 120cm x 80cm, and 2 at 240cm x 40cm to sttaddle the front corners. But I'm now wondering if this would be worth the effort and cost - even though I'm more than happy to do this if the results are much better, not least aesthetically!
My main wondering I'm hoping someone can help with as you've been great so far, is this: Is it possible that the duvets could actually perform better, as although they are nowhere near as dense, the coverage is far greater than I'd get from panels and my understanding is that in small room coverage is especially important.
Appreciate this is a complex science that I'm barely getting to grips with, but any insights really much appreciated!
Cheers :)
Gmonics22
Postby Sam Spoons » Fri Jan 31, 2020 2:52 pm
It is very complex but now you have convinced yourself of the benefits go to it, you can always add additional panels as time and budget allow. Received wisdom is that around ⅓ of the walls and ceiling covered with broad band absorbers (or bass traps) is about optimum, (ideally with another third covered with diffusion but in a small room decent diffusers take up a lot of space*).
* I have less than 1/3rd and no diffusion but my room sounds reasonably well balanced and free from too much dodgy 'small room' ambience. I may get around to posting a brief recording sometime.
Postby blinddrew » Fri Jan 31, 2020 3:53 pm
A lot of it comes down to what you can live with. If you're happy with a couple of duvets being up all the time (or with the putupandtakedown routine), then the performance gain for the cost of a couple of cheap mic stands and duvets is hard to beat.
But...
Corner traps and mineral wool will extend the efficacy of your control in the low end.
So if you don't mind the aesthetics, duvets at mirror points and mineral wool across the corners might give you your best bang for buck.
Postby Gmonics22 » Thu Feb 06, 2020 10:37 pm
Update:
So after lots of research I have constructed 2 broadband absorbers. 4' x 4' of 100mm RWA45 in wooden frames, with a breathable cotton covering. Experimented with placing them straddling the front wall corners (no difference) first reflection points (no difference) and back wall (no difference).
Feeling kind of defeated at this point. I wasn't expecting anything near a perfect room, but I have seen literally no improvement whatsoever. The honk is still overpowering everything. And now I have two giant turquoise monoliths mocking me while I cry at my desk, which now smells like a builders merchants. Time to give up or double down and make another 2? A happy accident at Travis Perkins gifted me another 4 slabs of Rockwool, which they don't want back. Little victories...
Gmonics22
Postby Sam Spoons » Thu Feb 06, 2020 10:58 pm
I put ten panels into my 4 x 4 m room. It's great for listening/mixing but still not dry enough for recording unless everything is fairly close miked. two 1200mm square panels will have made a difference but you need more, mirror points (there are at least four of those, side walls, back wall and ceiling. And probably behind the monitors. Then you need some additional bass trapping.
Rather than being despondent try recording some playback from the monitor speakers with a mic at the listening position then listen back with headphones so you can hear what improvement they are actually making. You made it work with duvets so you can make it work with 'proper' panels (and bear in mind that a double duvet is more than twice the size of each of your 1200mm2 panels).
Postby Martin Walker » Fri Feb 07, 2020 10:59 pm
Sam Spoons wrote:I put ten panels into my 4 x 4 m room.
I've got eleven bass traps in my small studio, which made a big difference, but it's still not perfect by any means.
I found vertically straddling the front corners was most effective, then the same for the back corners, and then a ceiling cloud.
Add to that some lighter traps on the early reflection points, and I was mostly there.
Postby Sam Spoons » Fri Feb 07, 2020 11:57 pm
Yup, that was the point I was trying to make :thumbup: I've just done some slightly more distant miking and have realised that, while my room is pretty good for listening it's not so good for tracking acoustic instruments without additional help.
Postby Hugh Robjohns » Sat Feb 08, 2020 12:45 pm
Gmonics22 wrote:It's completely untreated and bare at the mo, and it has a pretty horrendous resonance around 130hz which basically makes my kicks sound like they're running through a very intense short delay & metallic reverb!
That description sounds like you have a lot of flutter echoes in the room, which is not entirely surprising if it is completely untreated. But it would be worthwhile also making sure that you don't have something resonating from the vibrations -- other equipment in the room, speaker stands, tables, light fittings, loose rack bolts... it's amazing what can be set off in sympathetic resonance!
I'm hoping some bass traps in the corners and panels on the walls will help, but don't really know where to start and don't want to shell out on heaps of stuff to get no results.
Yes it will help, obviously. I wouldn't worry about bass traps for the moment -- you can add those later if necessary. I'd start with some broadband absorber panels on the side mirror points, and on the front and back walls. Depending on whether the floor is carpeted or a hard surface, you might end up needing something on the ceiling too, but again, that can be added later.
The first step would be to deal with sidewall and front-back reflections to try and kill all those flutter echoes. Typically, I'd aim to cover maybe 25-30% of the bare wall surfaces with absorber panels. Two large panels wont be that effective I'm afraid. Even small rooms would usually need 6-10 panels.... Albeit usually 2x4ft ones rather than 4x4ft monsters.
Postby CS70 » Sun Feb 09, 2020 1:12 pm
Gmonics22 wrote:Update:
Flutter echos! I have my home setup in a small extension of the main living room (choose your partner wisely ;-) ) and the room originally suffered from them horribly. Still does in the "dining space" proper. If you clap your hand, you can really hear a short metallic echo which is unbearable if you have minimally trained ears (the rest of the gang here, of course, notices nothing and just thing it's the TV which is not that good to listen to :) ).
Luckily these echos aren't hard to defeat. They are usually quite high frequency so they dissipate quickly with the distance and easy to absorb if you understand where they come from. Duvet have probably failed you because, if your room is anything like mine, the echos occur with reflections between floor and ceiling as much (or more) than walls. You can experiment simply by walking around and clapping your hands - if the timbre of the echo stays pretty much similar, it's likely its main component is due to floor-ceiling, which keep the same distance from you as you walk (as opposite to the side walls, obviously).
In my room, the main issue is flat wooden flooring and a very reflective material that was used to finish the ceiling. Walls are drywall with insulation sandwiched between them and the outer wood shell (it's Norway, it's cold and there's lots of wood so houses are mostly in wood).
At my mixing station, I cured that issue primarily by hanging a large broadband absorber/almost bass trap (sourced from a cine-room shop) on the ceiling, leaving about 15cm of air. Of course broadband panels all around and I have a couple of large cylindrical bass traps behind the speakers.
it's far from perfect but the difference between where I sit and just a meter on the side (in the dining room proper) is like night and day when it comes to dryness. The metallic ringing disappeared entirely (as much as my ageing ears can tell of course :) ) and what I mix on speakers turns out to be generally fine without much effort (I usually compare at the proper studio and there's little tweaking to do be done, mostly).
In short : try to place one of the traps you've built over your seat (or a bit back).. if you have a couple friends you could ask them to just hold it there for you. Remember - not flush with the ceiling, but with good space between. Hopefully you should see a remarkable improvement.
It will most likely be that you *still* need the duvets (or the panels) on the walls and the back of the speakers. If you use duvets, once again not flush on the wall, but with a good space between them and the wall.
Best of luck!
Postby Gmonics22 » Sun Feb 09, 2020 9:03 pm
Update:
Again, thanks to all for your suggestions and encouragement, you've really helped me keep the faith. Even though it's hard going I've found the enthusiasm to get to the stage of mixing a project today, which I haven't done in years!
A picture of where I'm at right now - can't work out how to embed it I'm afraid:
http://imgur.com/gallery/xAGZDEn
The whole setup is very temporary while I continue to experiment, but so far I've managed to get the troublesome 130hz and 200hz spikes down to within about +3-5db. Progress! As you can see I've bodged a ceiling cloud from 2 sofa cushions and a fleece blanket. This is going to be replaced with another 100mm Rockwool panel. At the moment the "air gap" is about 2ft... Once complete the side panels will be mounted with a 4inch gap, and the cloud a foot down.
Re the flutter echoes, this is more good information and something I'll be investigating. The floor is good thick carpet, but maybe some tasteful foam dotted around would be judicious. Luckily the colour scheme downstairs is a lot of charcoal grey...
Thanks folks :)
Gmonics22
Postby Martin Walker » Sun Feb 09, 2020 10:18 pm
So pleased to hear that you're moving forward - ceiling clouds can provide a surprising amount of acoustic improvement, basically because that replace an otherwise flat and totally reflective surface :thumbup:
Postby Martin Walker » Sun Feb 09, 2020 10:24 pm
Gmonics22 wrote:A picture of where I'm at right now - can't work out how to embed it I'm afraid: http://imgur.com/gallery/xAGZDEn
1. Just right-click on that image in your link and select the Save image address option.
2. Now click on the Img (Insert image) option above your in-progress SOS Forum post and then paste this image address in between its two halves, and you'll get:
(Love that temporary ceiling cloud :D 8-) :thumbup:
Postby CS70 » Mon Feb 10, 2020 10:30 pm
Great to hear. Fun with the cloud but that's really the trick more often than not.
Another couple of easy interventions: I can't really see the orientation of the monitors, but reflections from the hardwood desk can bounce back directly to your ears - if you orient them slightly upwards it can help - and/or moving them forward on the desk. I get the control surface needs space but it may be a little too long for my tastes. You could have it on
side car. Basically you want the cone of sound to get clear of the desk front border as much as you can. Looks like you have space for stands and they also could help, but definitely more forward. You may find that in that position you need to position (or better, add to) the cloud a bit behind your seat to keep on absorbing the high frequencies before the hit the ceiling.
Also I am not sure if the whey protein bins are empty or full :-) - fill'em with sand if they aren't.
Putting a fluffy carpet under the desk and your chair can also help a little - while a carpet is usually too thin to do much for anything that very high frequencies, in conjunction with the ceiling absorbers can further limit echos.
That window on the back is not that good - it will reflect some energy directly onto you. A bit counter-intuitively, larger monitors would help as their mount tend to have a bit of play so they dissipate high freq which hits the back a bit in my experience (I got better sound when I switched from one to two 27 inches monitors :) ). Ideally, you would want to cover it with an absorber - whether or not is feasible for aesthetic reason (or just light) is another matter of course.
Good to see you're making progress.
Random
Postby DanDan » Mon Feb 10, 2020 11:39 pm
You appear to be applying solutions without knowing the cause of the symptoms, or perhaps even the symptoms themselves. Honks can have many causes, but my gut instantly says ceiling or desk of some kind.
DanDan
Dan FitzGerald MIOA  MAES
www.irishacoustics.com
www.soundsound.ie
