Bluetooth Audio Transmitter IC for simultaneous transmission
Postby SAAD » Mon Nov 25, 2019 12:55 pm
Hello All,
I am looking for a recommendation for Bluetooth audio IC.
My usage is I want to connect a MIC with Bluetooth IC and Transfer its sounds simultaneously to Wireless headset and to mobile (android/iPhone) for sound recording purposes.
So my main usage is to listen and record it simultaneously through Bluetooth.
Thanks
SA
SAAD
Re: Bluetooth Audio Transmitter IC for simultaneous transmission
Postby Hugh Robjohns » Mon Nov 25, 2019 1:17 pm
Are you looking for a ready-made device to connect to a mic, or the actual chip to make up a DIY unit yourself? If the former, this forum is the best one... but if the latter I'll move it to the electronics and DIY forum.
Postby SAAD » Mon Nov 25, 2019 2:05 pm
I am looking for a DIY solution to customize the Bluetooth chip programming by my self.
SAAD
Postby Wonks » Mon Nov 25, 2019 2:22 pm
Bluetooth is very laggy, and not ideal for singing and monitoring on headphones at the same time. The delay between your voice and the headphone sound is very off-putting. The delay isn't an issue for recording, but you will probably struggle if you are the one singing and also monitoring yourself over Bluetooth headphones.
Postby cyrano.mac » Tue Nov 26, 2019 2:53 am
I don't think this can be done. BT isn't a network. It's a P2P connection.
Some devices perform the trick (connecting more than two devices) by sending it as a second stream. But even that is a hack at best. When you add an inherent 15 msec latency and DIY, I'd say you better look elsewhere. Like Dante. No DIY, not cheap. Or AVB, DIY possible, but far from easy.
cyrano.mac
